Is this normal - JeepForum.com
post #1 of 6 Old 04-18-2010, 01:11 PM Thread Starter
AM0608
Is this normal
I'm installing a 4" RC lift. On the front the spring goes in the shackle fine but for the frame mount it's about 4" too short.
AM0608 is offline
post #2 of 6 Old 04-18-2010, 02:11 PM
Fhajad
I personally never did a lift, but I'd imagine so. That way it actually has some force to push up with. Right now the leaf is under no pressure at all.
Fhajad is offline
post #3 of 6 Old 04-18-2010, 02:34 PM
NorthwestYJ
is this with the shackle bent or straight?
NorthwestYJ is offline
post #4 of 6 Old 04-18-2010, 02:35 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I often attach the spring to the spring hanger first, then the shackle end since the shackle end can swing back to couple with the spring eye.
Joe Dillard is offline
post #5 of 6 Old 04-18-2010, 03:03 PM
brunolinski
Completely normal. I have used a pry bar to get the eye in position. Use some muscle.
brunolinski is offline
post #6 of 6 Old 04-18-2010, 04:15 PM
fyrdriver
1983 CJ7
Do what Joe says, install the frame side first then you can slide the shackle rearward. If it doesn't reach then put a jack under the spring and compress it enough to bolt it to the shackle. Also dont tighten until everythings done then torque it down.
Firefighters Jeep Club
fyrdriver is offline
Is this normal? GLANGA88 TJ Wrangler Technical Forum 13 05-04-2014 02:28 PM
D35 ? is this normal df19087 YJ Wrangler Technical Forum 10 06-02-2009 07:17 PM
normal RPM for TJ? dptx76 TJ Wrangler Technical Forum 8 07-12-2006 08:52 PM
Is this normal? NMullens YJ Wrangler Technical Forum 2 11-03-2004 04:21 PM
Is this normal? bcmopar TJ Wrangler Technical Forum 4 10-05-2004 06:14 AM
