noob questions - JeepForum.com
post #1 of 19 Old 08-23-2012, 01:59 PM Thread Starter
sig81
noob questions
I've read through some of the faqs but didnt get exactly what I was looking for. I have a 92 or 93 wrangler 4cyl and I am looking for a lift kit. I would prefer to buy it as an entire package. can anyone tell what to companies to stay away from and what to look for in a kit? also eventually I am going to swap the 4 for a 6 cylinder. I am looking for a 4.5 lift not really looking to go any higher unless you guys think it would be wise to do so. I plan on taking it to some local trails and thats pretty much it. it is not a daily although I have been driving it everyday for the past week. oh and the front and rear diffs are coming out as well going to go with a dana 44 or ford 8.8. which vehicles can these be pulled from?
sig81 is offline
post #2 of 19 Old 08-23-2012, 02:59 PM
stilltippin
I think BDS makes the best suspension for the price.. and I 'd stay away from rough country- they seem pretty hit or miss- even though the warranty is very good.
Matt
Low Output Member #44
"There's a NEW Mexico?" -Mr Burns
stilltippin is offline
post #3 of 19 Old 08-23-2012, 04:23 PM Thread Starter
sig81
Matt
good thing I asked before I bought because I was looking at rough country
sig81 is offline
post #4 of 19 Old 08-23-2012, 04:32 PM
zholcomb
Go with a 5" BDS lift! If possible you should piece the lift together.
zholcomb is offline
post #5 of 19 Old 08-23-2012, 05:14 PM
roadyrob
1987 YJ Wrangler
go to the start page, down at the bottom is the review section, tons of info on lifts.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #6 of 19 Old 08-23-2012, 07:40 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You need to take a breath and start over.
What size tires are you going to run?
What kind of wheeling do you do?
Luck Favours The Prepared
Anticanman is offline
post #7 of 19 Old 08-24-2012, 01:31 PM Thread Starter
sig81
I was wanting a 4.5 but the 5" lift is cheaper for some reason. so I am going with that one
going to check it out now
I plan on 33's due to the fact that is what will fit with the lift height. dont know what kind of wheeling I'm going to do honestly. I just want to get into some mud and see what happens. I dont plan on driving the jeep around town its just a toy. I am new to this kind of thing. I came from front wheel drive turbo cars and that got boring so I am looking to get into some other expensive hobby.
sig81 is offline
post #8 of 19 Old 08-24-2012, 01:42 PM
zholcomb
You will need new Boomerang shackles to go along with the BDS 5" lift to clear the military wraps
zholcomb is offline
post #9 of 19 Old 08-24-2012, 01:58 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Choose tires first then the lift height. Not the other way around
post #10 of 19 Old 08-24-2012, 02:48 PM
dtn8tr
sounds like you'd be better off selling the YJ and buying one with a 6cyl in it already, as you're looking at a lot of work there and money also if you don't weld. Besides choosing tire size and then lift you will need to look at axles also. You can get 33"s without going for 4.5-5" of lift. It's called LCOG (Low Center Of Gravity). 3"s of suspension lift with 5/8 boomerangs and a 1" BL will pretty much get you there. Then you can also do things like Anticanman and get those spendy MetalCloaks that will give you extra room for travel without going higher.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #11 of 19 Old 08-24-2012, 04:10 PM Thread Starter
sig81
I will have to look into these boomerang shackles you speak of. I have not heard of these before. figured whatever would be needed in a lift kit would be supplied
I was set on 4.5 lift but bds 5" lift was cheaper. I saw somewhere that 33's would fit from like 1.5-5" lift. I could be wrong on that as I am taking in alot of info on this
if i am unhappy with the 4cyl I will swap something else in there. not a big deal small block chevys are a dime a dozen. I can also weld I am a pipefitter by trade and my friend has a welder plus he does some pretty good fab work. he actually knows more about trucks and such than I do he has just been busy working lately. I am pretty car saavy just dont know much about jeeps at all. its usually lowering not lifting. from what I have read so far a 4cyl will be ok for the most part just cant bigger than the ford 8.8 and 33's. not sure about driveshafts though. mine does have a bit of play so that will need some attention soon. any suggestions?
sig81 is offline
post #12 of 19 Old 08-24-2012, 04:28 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
So you're set on 33's then? 5" is way too much lift for that size tire especially since you don't know how much articulation you require.
post #13 of 19 Old 08-24-2012, 05:45 PM Thread Starter
sig81
not dead set on 33's. I was dead set on a 4.5 lift and 33's were the suggested tire size for the lift. I am guessing that the tire size could be bigger if I cut the fenders which is what I think you are suggesting. I am completely open to suggestions from you guys. how would I know how much articulation I need? I have never been wheelin before so I am just guessing right now.
sig81 is offline
post #14 of 19 Old 08-24-2012, 05:52 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
My suggestion to save a lot of headaches is to pick a tire size and build the jeep around that. It all revolves around tires. Do you have a sawzall? Do you have any aversion to using it on your jeep to make your tires fit? Let's just say 33" tires are what you're shooting for so you'll need maybe 2.5" of spring lift and either a body lift or that pesky sawzall to make some tj flares worthwhile. Here's a link to consider for clearance up front.
http://www.jeepforum.com/forum/f12/h...enders-1087408
Just remember that a little cutting can go a long way. My tires in this pic are 36's and I would have to say that my jeep doesn't look like a hack job. Not the cleanest in the world but not the worst I've seen.
post #15 of 19 Old 08-24-2012, 06:01 PM
mrdeath2000
exactly. You also need to consider regearing for the HUGE power loss you will notice going to 33's. Also consider the weaker rear axle. big lift means new brake lines, SYE, drive shaft, shims.
Depending how much money you want to spend and how much work you can do, it might be a better bet to get a ford 8.8 and just go spring over axle for your lift.
Seriously take a breather and check some stuff out, nothing sucks more than having to spend money twice or working yourself into a corner.
I run a 2.5" rough country lift, no issues, is it as nice as a BDS lift? No idea, never had one. is it better than my stock spings, sure is. I run 31's and have plenty of room for 33's, even 35's (also have 1" shackle and 1" body).
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
Noob questions, need help to help myself vegasvictim YJ Wrangler Technical Forum 2 08-14-2012 06:59 AM
Noob with noob questions. JonnyZero TJ Wrangler Technical Forum 17 12-28-2010 10:57 AM
BFG AT Noob Questions Seanbmc JK Wrangler Technical Forum 13 05-19-2009 03:10 AM
8.8 NOOB Questions 0II0 TJ Wrangler Technical Forum 8 05-20-2008 06:41 PM
some TJ noob questions... djb5118 TJ Wrangler Technical Forum 5 03-25-2008 02:23 PM
