noisy bearing - JeepForum.com
post #1 of 10 Old 08-18-2011, 02:53 PM Thread Starter
LordEnki
2006 WK
noisy bearing
I have a bearing gone bad. Its very annoying, but I don't know which one it is and would like to figure it out before I take the beast apart. With tranny in neutral and the clutch out its a loud whirring. When I step on the clutch pedal it stops. Which bearing could this be? All help is appreciated. Thanks.
LordEnki is offline
post #2 of 10 Old 08-18-2011, 04:57 PM
rustybeater
sounds like maybe a throwout bearing
rustybeater is offline
post #3 of 10 Old 08-18-2011, 05:24 PM Thread Starter
LordEnki
2006 WK
Does the throwout bearing only spin when the clutch pedal is not being pressed? Can other parts be damaged by a worn throwout bearing?
LordEnki is offline
post #4 of 10 Old 08-19-2011, 01:50 PM Thread Starter
LordEnki
2006 WK
Could anything other than a bearing be making this whirring sound?
LordEnki is offline
post #5 of 10 Old 08-19-2011, 03:22 PM
rustybeater
not really sure I just know i had a problem similar a long time ago and it was my throw out bearing
post #6 of 10 Old 08-19-2011, 03:38 PM
Newk76
sounds like what ours was doing....we did the clutch, throw-out bearing and a host of other things. not sure if it fixed it yet as we're doing some much needed body work now. will let you know when it's running again. rofl
Newk76 is offline
post #7 of 10 Old 08-19-2011, 05:56 PM Thread Starter
LordEnki
2006 WK
Thanks. Don't clutch kits usually come with the throw out bearing? If so, might as well change it all out I guess.
LordEnki is offline
post #8 of 10 Old 08-19-2011, 06:11 PM
Skydmark1
Sounds like a throw out bearing to me but I'm no expert on Transmissions
-2013 JKU Sport, bone stock, Auto with 3.73's
-1998 ZJ Laredo, 4.0 42RE Selec-Track, 30" M/T tires
Skydmark1 is offline
post #9 of 10 Old 08-19-2011, 09:23 PM
johnny27030
The throwout bearing should spin all the time. Its prob making a noise when its not loaded. When you press the clutch in it applies pressure to the bearing and puts a load on it. Ive had several cars with noisy throwout bearings. I havnt replaced one yet but that doesnt mean it wont fail on you. Mine were not a loud noise just a bit annoying. All clutch kits ive seen had a throwout bearing included. I cant see replacing just the bearing if you are going to pull the tranny, I would go ahead and do some preventative maintance and replace the clutch, pressure plate, pilot bearing and throw out bearing.
johnny27030 is offline
post #10 of 10 Old 08-19-2011, 11:06 PM Thread Starter
LordEnki
2006 WK
I do believe that's what I will do.
Maybe a few other things as well. Just for some reassurance.
Thanks for the input. I appreciate it.
Mike
LordEnki is offline
NVG3550 noises....Input bearing or throw out bearing? ROLLTIDEtj TJ Wrangler Technical Forum 44 09-03-2014 06:07 PM
Steering slop due to shaft bearing, can bearing only be replaced? Lemmiwinks TJ Wrangler Technical Forum 4 05-01-2011 06:53 PM
New D44 axle bearing. How to remove old bearing ring? thirdeye TJ Wrangler Technical Forum 5 04-30-2011 03:24 PM
Input shaft bearing or Throw out bearing? reisom TJ Wrangler Technical Forum 20 04-21-2011 09:19 AM
Noisy Pully (Bearing?) C2U5H TJ Wrangler Technical Forum 13 04-21-2009 12:55 PM
