Noise in the transmission - JeepForum.com
post #1 of 3 Old 09-09-2013, 04:06 PM Thread Starter
uvillegas
Hi, I have a 93 YJ, AX5 Manual 5 speed transmission standard, my problem is this:
When turning on the jeep not hear any noise in the transmission, but after a while I start to hear a noise like metal to metal and when I put decelerated fourth gear speed is thrown, I took off the transmission and changed one bearing then stopped the noise for a couple of days and was no longer thrown fourth gear, I noticed the gears were great.
After a couple of days I noticed a leak and had to go back down the transmission because it was missing an o ring and was leaking clutch oil pump and when put it back continued to be hearing the noise and again the fourth gear thrown away. Now I feel less powerful speeds.
Anyone have any idea what is happening?. Anyone know why the noise?
In advance, thank you all.
uvillegas is offline
post #2 of 3 Old 09-09-2013, 08:49 PM Thread Starter
uvillegas
By the way, when i push the clutch stop the noise
post #3 of 3 Old 09-10-2013, 12:30 AM
ashland82391
Pretty sure that's a bad throw out bearing. Someone correct me if I'm wrong.
ashland82391 is offline
