No vacuum at idle - JeepForum.com
post #1 of 15 Old 09-01-2014, 02:30 PM Thread Starter
snowplowdog
No vacuum at idle
I picked up a vacuum tester so I can diagnose the problems I'm having in my 90 YJ. The only line other than the one for the pcv/brake booster is in the carb so that's where I hooked up. I get no reading whatsoever at idle and it jumps up as soon as you hit the throttle. Shouldn't there be a port coming out of the intake manifold somewhere. I've looked but I cant find anything anywhere. Some days id really like to shoot the PO of this jeep.
Never attempt anything you don't want to have to explain to the EMT
snowplowdog is offline
post #2 of 15 Old 09-01-2014, 03:02 PM
Mike Romain
The line off the back corner of the stock carb that goes to the air filter is a manifold vacuum.
Mike
Mike Romain is offline
post #3 of 15 Old 09-01-2014, 03:32 PM Thread Starter
snowplowdog
Sorry, forgot to mention its not a stock carb....PO replaced it with a holley
post #4 of 15 Old 09-01-2014, 04:14 PM
dancytron
There is a big port on the manifold behind the carb that goes with the decel valve. There is also another one that goes to the heater controls.
http://home.sprynet.com/~dale02/decel.htm
dancytron is offline
post #5 of 15 Old 09-01-2014, 04:24 PM Thread Starter
snowplowdog
Mine doesn't have any of that. The PO ripped out all of the vacuum lines and everything that he thought wasn't needed when he installed the new carb. It looks as though I'll have some "plumbing" to do in order to get this thing right.
post #6 of 15 Old 09-01-2014, 04:55 PM
dancytron
The port should still be there through. It would be under where the decel valve used to be.
Unless he actually sawed it off and welded it shut.
post #7 of 15 Old 09-01-2014, 04:59 PM
Old4X
1990 CJ7
The line to the brake booster is a vac line, or did the PO remove the brakes also?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 15 Old 09-01-2014, 05:05 PM Thread Starter
snowplowdog
Looks as though he plugged it. I asked him if he had any parts left from when he did the carb swap and he gave me a bunch of stuff, including the original intake manifold. Apparently they broke it while bolting the new carb on so they had to replace it with a new one.
I'm thinking this is the little guy I'll need to install in the manifold...
post #9 of 15 Old 09-01-2014, 05:10 PM
dancytron
Attachment 1579386
That is the CTO valve. It is a temperature triggered valve that operates the EGR valve and the Vapor Canister.
edit: So the intake manifold may not be stock either. Could be off a 4.0 or something after market. Can't help you much then.
post #10 of 15 Old 09-01-2014, 05:24 PM Thread Starter
snowplowdog
He said they ordered an OEM manifold, but that doesn't mean anything.
I'll have to look under there again, maybe I'm missing something.
post #11 of 15 Old 09-01-2014, 08:51 PM
bpounds
bpounds's Avatar
It is normal to have no vacuum on a ported source at idle. Because the carb throttle plates are closed.
The nipple manifold vacuum that is used for your brake booster should have a smaller side nipple that is a good source of manifold vacuum. It is right above the EGR valve. You can see it below my throttle body in this pic.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #12 of 15 Old 09-02-2014, 07:04 AM
Mike Romain
There is a line off the back corner of the intake for the heater controls under the dash. That one should still be there. Also one going to the front axle disconnect.
Mike
post #13 of 15 Old 09-02-2014, 11:39 AM Thread Starter
snowplowdog
I'll be looking tonight after work.
post #14 of 15 Old 09-02-2014, 08:07 PM Thread Starter
snowplowdog
Here are some pictures of the 2 vacuum lines that are on my jeep.
The large on that comes off the back of the carb is for the PCV valve & brake booster. The small one tees off for the vacuum advance and front axle disconnect. There are threaded plugs all over the manifold, can one of these be used for a vacuum port?
post #15 of 15 Old 09-02-2014, 10:11 PM
Drednot
Yes, one of the ones on top to the rear of the carb. They should all be manifold vacuum.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
