No start unless moving 4H shifter - JeepForum.com
post #1 of 12 Old 05-12-2015, 11:20 AM Thread Starter
chumpmann
94 yj 4.0 auto
Ok, had no problems at all until pulled in to gas station,
went to start it, no turnover, Lights, radio, door buzzer all working fine,
after looking under hood, went to start again, and I happened to move the 4H shifter and it started.
is there something with the shifter that would cause it to not start? or start?
jeep runs great, doesn't die, idles smooth.
THanks for any input!
"Never trust quotes on the internet" - Bejamin Franklin
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
Other Jeeps...
1994 YJ - 2.5" RC lift, 31x10.5 BFG AT
Hers - '07 XK
chumpmann is offline
post #2 of 12 Old 05-12-2015, 11:26 AM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
I can't see the transfer case shifter having anything at all to do with that. Maybe you jiggled the column shifter also....neutral safety switch?
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 12 Old 05-12-2015, 12:09 PM
Que89YJ
It has to be the switch. You need to get up under it and look at the NSS.
Que89YJ is online now
post #4 of 12 Old 05-12-2015, 01:17 PM Thread Starter
chumpmann
That has me stumped also.
OK, I will check out neutral safety switch, does anyone have a pic of where it is located?
thanks
Other Jeeps...
Hers - '07 XK
post #5 of 12 Old 05-12-2015, 02:22 PM Thread Starter
chumpmann
Is this the part I need?
Other Jeeps...
Hers - '07 XK
post #6 of 12 Old 05-12-2015, 04:31 PM
Que89YJ
It looks like it but check your old one. You could have just a bad wire.
Fault codes:
Mean Max pics of everything:
No Start:
post #7 of 12 Old 05-13-2015, 09:35 AM Thread Starter
chumpmann
Ok, thank you, Will see if I can find where it goes.
Other Jeeps...
Hers - '07 XK
post #8 of 12 Old 05-20-2015, 04:09 PM Thread Starter
chumpmann
Is this going to be located on the transmission?
Anyone give me an idea where to look?
thank you
Other Jeeps...
Hers - '07 XK
post #9 of 12 Old 05-20-2015, 04:28 PM
Que89YJ
Youtube yj nuetral safety switch. They Have a few videos of it.
Fault codes:
No Start:
post #10 of 12 Old 05-22-2015, 04:54 PM Thread Starter
chumpmann
Ok, replaced the Neutral safety switch, still not starting.
It was starting by moving the 4H shifter, but started not doing anything, I then replaced the NSS, still nothing.
Anyone have any suggestions as to what to look at next?
Other Jeeps...
Hers - '07 XK
post #11 of 12 Old 05-22-2015, 04:59 PM Thread Starter
chumpmann
It's getting power, But not turning over at all.
turn the key, and nothing.
Other Jeeps...
Hers - '07 XK
post #12 of 12 Old 05-22-2015, 05:07 PM Thread Starter
chumpmann
tapped the starter with a hammer, and it started, guess its the starter
Other Jeeps...
Hers - '07 XK
