No Start Issue - JeepForum.com
post #1 of 8 Old 11-05-2013, 10:22 AM Thread Starter
Peety
No Start Issue
Hi All, I'm a newb here...
Here's what I have, and what's going on...
88 YJ
4 Sleepy Squirles
I replaced the clutch two weeks ago and it would not start. I should add that I drove it into the garage.
Supplemental investigation has gotten me to this point.
-Fuel Pressure is good
-Have spark
-Good compression
IF I SPRAY CARB CLEANER IN THE TB, the jeep will run, and STAY running until I cycle the key off, otherwise it will just spin over. If i attampt to re-start it with the key (or a jumper to the starter solenoid) it will only spin. If I give it a shot, it will start up and stay running, every time.
There is NO injector pulse while cranking the engine, only after the starter has disengaged.
Any help would be HUGE
Peety is offline
post #2 of 8 Old 11-05-2013, 10:35 AM
Zigzbox
i had a not starting problem once after a oil change wound up that i bumped a connection that goes the the dizzy cap alittle above the oil filter on the 4.0 after i checked my connections and made sure all the plugs where good and then it started i donno if this will help i wish you luck
Zigzbox is offline
post #3 of 8 Old 11-05-2013, 10:41 AM
Que89YJ
Look at your WOT switch. Download the service manual and adjust the the tps, IAC and WOT
Here is a link for the FSM. Follow the adjustments on all the sensors.
http://dl.dropbox.com/u/40590346/87-88%20YJ%20Jeep%20Wrangler%20FSM%20manual.pdf
http://dl.dropbox.com/u/40590346/1990%20Jeep%20Factory%20Service%20Manual.pdf
Que89YJ is offline
post #4 of 8 Old 11-05-2013, 10:43 AM
Que89YJ
And...thanks for filling out your profile.
Que89YJ is offline
post #5 of 8 Old 11-08-2013, 11:22 AM Thread Starter
Peety
Thank You !!
It was the WOT switch, it had the ECU in fuel cut, DUH !!!!!!!!!
Peety is offline
post #6 of 8 Old 11-08-2013, 11:48 AM Thread Starter
Peety
On a related note, could someone post a pic of where the "double" fuseable link at the starter relay-ish mounts up.
Peety is offline
post #7 of 8 Old 11-08-2013, 12:04 PM Thread Starter
Peety
Here is a pic of the double link
Peety is offline
post #8 of 8 Old 11-08-2013, 01:05 PM
Que89YJ
I get them right on ocassion. Lol Glad you got it running. Thanks for posting back the fix.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
