No Start in cold weather - corrosion on a wire - JeepForum.com
post #1 of 1 Old 07-04-2010, 11:50 AM Thread Starter
jeepkween
My Jeep hasn't been starting in cold(ish) weather. I looked through the Hard or No Start/Long Crank in the Cold thread. Got to the ECU test, pulled the wire harness off and took the cover off.
On the third wire, which is the main power from the battery, is massively corroded. I've been slowly cleaning away the corrosion to see the wire. It's pretty bad. Some wires inside the casing have broken or are about to break.
This is RIGHT at the end of the wire, where it goes into the plug. How would I go about fixing/cleaning this? It looks like the corrosion goes inside the plug as well. (There is also corrosion inside the terminals, but I've found a way to clean those.) Do those wires just pull right out? Or should I not do that? Do I have to get a whole new plug and disconnect/reconnect 60 wires, just for one bad wire?
1990 Jeep YJ: Chevy 350, Auto Trans., Rear Axle ARB Air Locker, 4" Lift, 35"x12.5"-15 BF Goodrich All Terrain T/A tires
Other Jeeps: 1998 Grand Cherokee 5.9 Limited; 2002 Grand Cherokee Overland 4.7L
jeepkween is offline
ecu , wires , wiring harness
91 won't start in cold weather? medtech YJ Wrangler Technical Forum 7 11-16-2016 04:18 PM
Cold Weather Start - Grinding ten27oh4 JK Wrangler Technical Forum 19 01-04-2011 02:52 PM
YJ won't start in cold weather dimjeep YJ Wrangler Technical Forum 2 02-27-2010 11:01 AM
Cold Start New to Cold Weather Thexonexkid TJ Wrangler Technical Forum 18 12-02-2009 12:39 PM
Hard to start in Cold Weather Kiwi_TJ TJ Wrangler Technical Forum 4 06-05-2009 06:31 AM
