no start, brake lights didn't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > no start, brake lights didn't work
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 04-05-2010, 03:52 PM   #1
njmrenegade
last night after a movie it was about 10*C and we get in the jeep, i turned the key and got the dash lights on but no start, this happened before and everything electrical worked, so last time i pushed the brake and it started after that, i tried that again last night and there was alot of resistance and the brake lights didn't work, anyone know what the hell is going on?
njmrenegade is offline   Reply With Quote Quick reply to this message
Unread 04-05-2010, 04:09 PM   #2
idaholtby
Hard to say with your description. Does you CEL lamp come on when the ignition is first turned on before going to start when this problem presents it'self?
idaholtby is offline   Reply With Quote Quick reply to this message
Unread 04-05-2010, 05:05 PM   #3
njmrenegade
i can't remember if the light came on before or after, i should have ran a code, is there any other things you would need to tell what the problem is
Unread 04-05-2010, 05:58 PM   #4
idaholtby
Well,.. Check and pay attention to the CEL lamp the next time you try to start when this problem occurs. If the CEL does not light with the ignition turned on before you go to start, then you likely have bad capacitors in your ecm (don't fret, it is easily repaired for $5bucks if this is the case). You need to rule this out before looking elsewhere.
Unread 04-05-2010, 06:12 PM   #5
njmrenegade
ok ill try to remember that, thanks
