no start, brake lights didn't work - JeepForum.com
post #1 of 5 Old 04-05-2010, 02:52 PM Thread Starter
njmrenegade
last night after a movie it was about 10*C and we get in the jeep, i turned the key and got the dash lights on but no start, this happened before and everything electrical worked, so last time i pushed the brake and it started after that, i tried that again last night and there was alot of resistance and the brake lights didn't work, anyone know what the hell is going on?
njmrenegade is offline
post #2 of 5 Old 04-05-2010, 03:09 PM
idaholtby
Hard to say with your description. Does you CEL lamp come on when the ignition is first turned on before going to start when this problem presents it'self?
idaholtby is offline
post #3 of 5 Old 04-05-2010, 04:05 PM Thread Starter
njmrenegade
i can't remember if the light came on before or after, i should have ran a code, is there any other things you would need to tell what the problem is
post #4 of 5 Old 04-05-2010, 04:58 PM
idaholtby
Well,.. Check and pay attention to the CEL lamp the next time you try to start when this problem occurs. If the CEL does not light with the ignition turned on before you go to start, then you likely have bad capacitors in your ecm (don't fret, it is easily repaired for $5bucks if this is the case). You need to rule this out before looking elsewhere.
post #5 of 5 Old 04-05-2010, 05:12 PM Thread Starter
njmrenegade
ok ill try to remember that, thanks
Brake Lights not working...all other lights work Dashash TJ Wrangler Technical Forum 15 12-28-2016 01:20 PM
Lights and Accesories work, but won't start YJMan327 YJ Wrangler Technical Forum 3 03-12-2010 08:22 AM
brake lights don't work when lights are on driftbandito YJ Wrangler Technical Forum 3 12-02-2008 01:35 AM
brake lights don't work at all. jeep n00b YJ Wrangler Technical Forum 11 03-12-2008 06:35 PM
brake lights don't work mcruickshank YJ Wrangler Technical Forum 3 05-30-2007 08:56 PM
