No Start After Bad Jump Start Attempt - Page 2 - JeepForum.com
post #16 of 25 Old 08-27-2013, 02:33 AM Thread Starter
vrsoft
Picked up my parts today:
1 x A1 Cardone Remanufactured Distributor $93
1 x Cap $30
1 x Rotor $8
I thought the distributor assembly would come with the cap and rotor. I was wrong
I studied the FSM on the distributor removal/installation procedure the night before so I was prepared to do the work this evening. The procedure is surprisingly simple. I manually rotated the engine to 0 degrees and ensured the rotor ended up in the 5 o'clock position. Made my markings etc. Was starting to get excited at the thought that my YJ just might fire up tonight... and then came the distributor hold down bolt.
NEXT STEP(S)
Long story short, I'll be picking up a distributor wrench tomorrow so I can get the bolt off (and a new distributor gasket as I can't for the life of me find where the one in the box went - it must have fallen out as I was leaving the parts store earlier in the afternoon).
The saga continues
1993 YJ 4.0L
1999 XJ 4.0L (Going up for sale very soon)
2007 XK 5.7L
vrsoft is offline
post #17 of 25 Old 08-27-2013, 02:44 AM Thread Starter
vrsoft
By the way, my existing distributor is pretty brown and dusty on the inside. I was quite surprised actually when I pulled the cap off. I'll try to grab some comparison pics (old vs. new) to share with everyone once I get the swap-out done.
1993 YJ 4.0L
2007 XK 5.7L
vrsoft is offline
post #18 of 25 Old 08-27-2013, 09:21 AM
Que89YJ
Make sure you mark the distributor position.
Que89YJ is offline
post #19 of 25 Old 08-28-2013, 04:35 AM Thread Starter
vrsoft
CONCLUSION
SOLVED
Got the distributor off with a distributor wrench that I picked up on the way home today. The root cause of my issue was the camshaft position sensor was corroded and physically broken. It doesn't appear that my bad jump start was related to this ignition failure (thank goodness!)
Started up on the first try after the install. I feel great. I learned a TON of new stuff. Thank you everyone for your help along the way!
If anyone has questions about anything I did, or would like to see photos of the distributor removed etc (I took a bunch of photos), please don't hesitate to ask.
I really hope this thread helps someone else down the road.
Signing off, until my next post! Thanks again!
1993 YJ 4.0L
2007 XK 5.7L
vrsoft is offline
post #20 of 25 Old 08-28-2013, 05:12 AM
Que89YJ
That thing had water in it too! Glad to hear its working.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #21 of 25 Old 09-13-2013, 03:11 AM Thread Starter
vrsoft
I'm very glad too! I've been doing preparation work ever since for emissions trying to get plates back on my YJ (after 4 years of having it parked... I know, shameful!!). A little bit each evening... Tune-up and cleaning iac etc. I'll be siphoning out the old gas in the next 2 days, refilling with fresh, going for a long drive with the family and then doing the emissions test. I have a concern of oil leaking into the cylinders... So we'll. see what happens when I get the old gas out and take it from there. There will be a compression test done soon either way (my 1st one... I'm exited!
Thanks again for you help. I've been going through other posts from you, and you are really awesome to have as a connection though this forum community. You help so many people!
1993 YJ 4.0L
2007 XK 5.7L
vrsoft is offline
post #22 of 25 Old 09-13-2013, 04:18 AM
Que89YJ
You don't need to siphon it. Take the line going into the fuel rail off. Ron a hose I into a gas can and then jumper the fuel pump relay between 30/87. You can empty the track in a few minutes.
Fault codes:
No Start:
Que89YJ is offline
post #23 of 25 Old 09-13-2013, 04:23 AM Thread Starter
vrsoft
That's brilliant!!! ... And I know exactly how to jump the relay since I played around with it while diagnosing what turned out to be my distributor failure.
Thanks!!
1993 YJ 4.0L
2007 XK 5.7L
vrsoft is offline
post #24 of 25 Old 09-14-2013, 04:21 AM Thread Starter
vrsoft
Worked like a charm!! I was able to use the fuel pump to out 30L of old fuel before the pump stopped pushing of out.
Piece of advice for others... Don't try to jump your ASD relay thinking it will trigger your fuel pump. I was so excited to try this technique for getting the gas out that it took me 15mins to realize that I wasn't jumping the Fuel Pump relay! (Lol)
Got fresh fuel in the tank now and Jeep is running so much better. Emissions test tomorrow, here we come!
Thanks for this trick Que89YJ!!
1993 YJ 4.0L
2007 XK 5.7L
vrsoft is offline
post #25 of 25 Old 09-15-2013, 11:34 PM Thread Starter
vrsoft
Emissions test just (barely) passed. Another YJ back on the road!!
Now... on to the next project!
1993 YJ 4.0L
2007 XK 5.7L
vrsoft is offline
