No Start 89 yj 2.5 - JeepForum.com
post #1 of 3 Old 08-17-2011, 04:08 PM Thread Starter
jeepin100
No Start 89 yj 2.5
Hello!!! I have a 89yj 2.5 no start ! no spark out of wires ,have replaced coil didnt fix prob.someone said computer ? dont want to spend the money if not prob.I need help
jeepin100 is offline
post #2 of 3 Old 08-17-2011, 04:28 PM
R3V413
Have you checked your CPS(crankshaft positioning sensor)?
R3V413 is offline
post #3 of 3 Old 08-18-2011, 06:53 AM
Que89YJ
Hey Jeepin, I saw your post on the other thread. You need to start by figut=ring out if its fuel/spark or both. Check to see if the full pump goes on then off when you cycle the key and if you have spark at the plug when you turn it over.
Que89YJ is offline
Cold Start Turned Into No Start...Problem Resolved...Lesson Learned... tony673 YJ Wrangler Technical Forum 2 10-02-2011 08:49 PM
Can you push start / bump start a TJ? (posts from Boonie Mechanic tricks thread) Wheelin98TJ TJ Wrangler Technical Forum 162 02-09-2011 12:50 AM
Rough idle at start question....opinion before I start spending money. Cali04LJ YJ Wrangler Technical Forum 1 08-23-2010 11:07 AM
Jump start = Volt Meter spikes while driving then wont start AWILD TJ Wrangler Technical Forum 5 02-21-2010 06:37 PM
1997 2.5 will not start on incline and rough start/idle when cold. BuckeyeTJ TJ Wrangler Technical Forum 0 11-24-2009 10:39 AM
