No speedometer lights - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > No speedometer lights
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 05-27-2015, 06:18 PM   #1
dhunt09
Hey guys,
So the Jeep has never had working speedo lights since I've owned her and I'm finally over it.
I know that its not due to blown bulbs, fuse, or corroded wedge base sockets. I am not sure what to check next. If it helps, the gauge functions fine, and everything else in the dash works and illuminates for that matter.
This is the speedo side of the cluster should it help. Perhaps I'm missing something that I am unaware of.
Attachment 2144058
I have also considered using a couple of these, they are the wedge sockets that are normally used but with their own wires. Any ideas on how I can wire these so that my dash light switch will turn them on with all the others?
Attachment 2144066
Any advice is greatly appreciated.
-Devin
dhunt09 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 11:43 AM   #2
Que89YJ
Just wire it directly to the power connector lighting wire and ground. It should only take you a few minutes. If I remember right the lighting power is orange and ground is black.
Que89YJ is offline   Reply With Quote Quick reply to this message
