No speedometer after SYE install... - JeepForum.com
post #1 of 7 Old 06-22-2013, 08:57 AM Thread Starter
jason280
Recently finished a 3.5" lift & Rugged Ridge SYE install, and now the speedometer has stopped working. Speedo was working fine prior to the install, and I have checked the connections twice going to the speed sensor on the transfer case. Any idea or guesses on the issue? Blue speedometer gear was installed with the SYE, so I am not sure what the issue is. Thanks!
None
jason280 is offline
post #2 of 7 Old 06-22-2013, 09:11 AM
XJ93
Sounds like you need to reclock the sensor. There are numbers at four points on the outside edge of the sensor that will correspond with the number of teeth on your gear. You need to make sure that the numbers you need are in the 6 o'clock position.
XJ93 is offline
post #3 of 7 Old 06-22-2013, 10:10 AM Thread Starter
jason280
Huh, never knew the orientation made any difference. I'd always wondered what the different notches were for on the housing, guess I know now!
None
jason280 is offline
post #4 of 7 Old 06-22-2013, 07:01 PM
UZI4U
Your gear is marked with the number of teeth it has. When you clock it, the number range your gear fits in will be facing you.
MCLMM
UZI4U is offline
post #5 of 7 Old 09-16-2013, 07:14 AM
rambo3489
So if I'm reading this right sounds to me the sensor housing is slightly off center? Thus by "clocking" it moves the gear closer and further from the output shaft. My speedo has stopped working. It registers if I use a drill on the cable but I get nothing when in the tcase.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #6 of 7 Old 09-16-2013, 07:21 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Read this thread, post #27.
http://www.jeepforum.com/forum/f12/s...-still-695330/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #7 of 7 Old 09-16-2013, 07:26 AM
rambo3489
Originally Posted by Mean Max View Post
Just got finished reading it. Thank You sir.
<a href="
THE YJ MY WAY</a>
