no spark . wo'nt start. Help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > no spark . wo'nt start. Help!
Unread 03-28-2002, 06:19 PM   #1
tonyxjyj
drowned it at local mud hole. (last week end)everything is dry now. no spark to the plugs. checked coil,fuses,fuse links. whats next?
tonyxjyj is offline   Reply With Quote Quick reply to this message
Unread 03-28-2002, 09:18 PM   #2
FLHT_FXRS_YJ
Ignition Module - a possible source of the problem.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline   Reply With Quote Quick reply to this message
Unread 03-30-2002, 09:16 AM   #3
tonyxjyj
Ingition module was it ! It got slammed by a root or something. wheel well where it was mounted was bent and aluminum case for module cracked. replaced it and remounted it higher up, hopefuly out of harms way.
Unread 03-30-2002, 09:54 PM   #4
FLHT_FXRS_YJ
Cool!
Unread 03-31-2002, 02:09 AM   #5
Roachen
Ignition module man, gets ya everytime. When I breakdown, the fisrt thing i check is ign. mod. now.
Roachen is offline   Reply With Quote Quick reply to this message
