No spark..replaced crankshaft sensor, ignition coil, distributor(rotor and cap) - JeepForum.com
post #1 of 5 Old 03-08-2009, 08:13 PM Thread Starter
amsgwp
What do I do next? I have a multimeter so is there anything I can check before replacing the computer? It's $250 and I don't even know if that is going to fix the problem. I once found something on the internet about some specific wires that get corroded easily and need to be checked but I have been unable to find this anywhere.
Any help will be much appreciated!
amsgwp is offline
post #2 of 5 Old 03-08-2009, 08:16 PM
EK91YJ
Was there any codes from the computer?
Red 5.3L LM7 in progress 4 inch Rubicon Express
EK91YJ is offline
post #3 of 5 Old 03-08-2009, 08:19 PM Thread Starter
amsgwp
that is the first thing I am checking when I get to the jeep. It's in the fiance's garage so I don't have quick access to it. I'll go over in the morning and check for codes.
Out of all the searching I did last summer, I never found anything about checking these codes. But I did find that information today. So I'm going to check it first thing and see what codes it shows.
If the ECU is shot, what type of code would I expect? Would anything show?
amsgwp is offline
post #4 of 5 Old 03-08-2009, 08:40 PM Thread Starter
amsgwp
Okay I found this great thread on repairing the ECU
http://www.jeepforum.com/forum/f12/how-repair-your-ecu-591031-post6007666/
Now, I have a quick question about this thread. The ECU's he fixed did not contain this gel(jello like) covering over the electrical components. How do you remove this stuff?
amsgwp is offline
post #5 of 5 Old 03-08-2009, 09:16 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
http://www.jeepforum.com/forum/showthread.php?p=6007666
actually that thread is for a pre 91 2.5L engine controller. you need this one, and the thread that will isolate the computer as being the problem.
http://www.jeepforum.com/forum/f12/crash-course-brain-surgery-replacing-capacitors-ecu-492597/
http://www.jeepforum.com/forum/f12/91-hard-no-start-long-cranks-cold-explained-490788/
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
Ignition Coil and Crankshaft Position Sensor ThatGuysXJ TJ Wrangler Technical Forum 16 04-12-2015 12:29 PM
Distributor Cap/Rotor/Spark Plugs/Wire Set digizure YJ Wrangler Technical Forum 7 06-29-2009 07:43 PM
Desperation, 1993 Jeep will not fire..replaced brain, crank sensor, ignition coil... amsgwp YJ Wrangler Technical Forum 3 03-24-2009 12:15 PM
What spark plug, cap, rotor, coil and wire combo is the best for the 4.0L? Zew TJ Wrangler Technical Forum 9 01-26-2007 06:23 PM
need help FAST yj has no spark new coil,plugs,wires,cap,rotor danimal225 YJ Wrangler Technical Forum 2 02-11-2004 07:25 AM
