No spark, no start.... - JeepForum.com
post #1 of 6 Old 08-31-2011, 09:25 AM Thread Starter
AnonymousD
My Jeep randomly died pulling into tha gas station a few days ago, and now it wont start. I checked it and Im not getting spark at the plugs, and then I checked it coming off the coil. No spark there either.
So what else do I need to check?
AnonymousD is offline
post #2 of 6 Old 08-31-2011, 10:26 AM
nembudonna
Check all your connections and be sure they are clean. Next check your coil wire and coil. Then your cps and your ecm.
nembudonna is offline
post #3 of 6 Old 09-01-2011, 07:44 AM
afhanson72
Sounds like a bad coil. Mine did exactly the same thing and that's what the problem was.
Al
94 YJ - Plenty of mods
afhanson72 is offline
post #4 of 6 Old 09-01-2011, 07:50 AM
Que89YJ
Check your fault codes by cycling the key. Judging by the number of post you have I know you know the routine. Does the fuel pump cycle when you turn the key. Chances are its the Crank position sensor.
Que89YJ is online now
post #5 of 6 Old 09-01-2011, 07:54 AM
Smitty777
fuel and fire man....if you lost both..definately cps.
Smitty777 is offline
post #6 of 6 Old 09-01-2011, 08:28 AM
asbury
it's a bad crank sensor , located on drivers side bell housing at 11:00
JEEP NAKED !!
asbury is offline
94 yj no spark, no start 97mrnsgt YJ Wrangler Technical Forum 15 05-23-2014 05:04 PM
No start, no spark, what's next? bigred33 TJ Wrangler Technical Forum 14 03-25-2011 06:43 AM
No spark on start, one spark on run. Benny88 YJ Wrangler Technical Forum 7 03-05-2010 02:38 PM
89 2.5 won't start... no spark JimenyFKrickets YJ Wrangler Technical Forum 2 02-17-2008 06:16 PM
Won't start, no spark timhall YJ Wrangler Technical Forum 16 10-21-2004 05:58 PM
