No spark no fuel in my 95 wrangler - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > No spark no fuel in my 95 wrangler
Jeep Wrangler Complete Gear Upgrade Kits with Installs andUSA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Jeep Long Arm Upgrade Kits on SALE for as low as $649.95 S
Unread Today, 08:50 AM   #1
Yjwranglerdan
I just recently purchased a 95 wrangler 2.5 manual transmission and it currently has no spark and is gettin no fuel I tried doing the key trick to get the check engine to flash but currently it won't I'm assuming it's a bad ecu as I have read up on trew out the week looking forward on hearing and suggestions thanks
Yjwranglerdan is online now   Reply With Quote Quick reply to this message
Unread Today, 09:28 AM   #2
mike134
when you first turn the key from OFF to ON (not start) do you get a solid ON Check Engine Light for a few seconds? If not, then you should consider brain surgery to repair your ECU. it costs about 50 cents: http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
ALL ECUs will succumb to this at some point. It is just a matter of time...
mike134 is online now   Reply With Quote Quick reply to this message
Unread Today, 11:02 AM   #3
Que89YJ
Check the power to the ecu first like the
http://www.jeepforum.com/forum/f12/9...lained-490788/
If power there ecu fix time.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread Today, 11:51 AM   #4
Awesome
First thing to check is your fuses. Don't start modifying your ECU before you have ruled out other causes. Find a wiring schematic and find out if you can hotwire the Jeep to start (it's not hard and only requires one wire). If you can, then you've got a bad fuse or fusible link somewhere.
I had the same problem once. Turned out to be corroded fuses.
”This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!” ~Adolph Hitler, 1935, on The Weapons Act of Nazi Germany
Awesome is offline   Reply With Quote Quick reply to this message
Unread Today, 12:26 PM   #5
ttop191
Crank sensor. Never had that issue on my yj but 4 out of the 6 xj's I owned did that. Was always the crank sensor
ttop191 is offline   Reply With Quote Quick reply to this message
