no spark - 88 4.2 - JeepForum.com
post #1 of 3 Old 08-09-2010, 04:39 PM Thread Starter
cgoldhill
no spark - 88 4.2
I was out driving one day and the jeep was randomly missing and bucking, backfired and popped through the intake once or twice. Got it up to work the next day and checked my timing. while i was fiddling, it died on me once or twice and i could hear the coil arcing when i pulled on the distributor wire. popped the cap and saw the pick up was mucho loose so i got a new distributor. put the new one in and got no spark, bought a new coil and ICM and still no spark. Tested everything and it all seems good to go. Coil gets power, ICM gets power and signal from the distributor. Even tried the nutter bypass to take the ECU out of the loop and still nothing
Any ideas at all? It cranks but no spark. Ive been reading around and see that the icm casing itself may not have a good ground. I'm fresh out of ideas and I'm on the verge of buying an MSD box. Just dont want to keep throwing money at it though. All help appreciated
cgoldhill is offline
post #2 of 3 Old 08-09-2010, 07:25 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Here is a link in JF that addresses the ICM:
http://www.jeepforum.com/forum/f8/wh...module-890279/
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 3 Old 08-09-2010, 07:50 PM
ScottsYJ
I had a similar problem with my 88 and the ICM. Pulled the one from my bosses Jeep and everything worked fine. Put mine back in and it worked fine for a week and started acting up again. I went back and forth between another OEM ICM or the MSD. Went the MSD and am glad I did. Jeep starts and runs better than ever before. I'm sure there are those that will say the MSD is overkill but I'm happy, my jeep runs better and thats what matters.
Proud YJ owner since 10.25.2008.
Teamrush mod, MC2100 carb, Nuttered, BDS 2" Lift kit, BrandonYJ Shackles 1/2", AA SYE, Tom Woods DS,
31" Goodyear Duratracs, Magnaflow CAT, Flowmaster Delta 40 Muffler, Monstalined, MSD 6A Ignition
ScottsYJ is offline
No spark during crank but spark when key released...WTF? USMC_JeepGuy YJ Wrangler Technical Forum 16 08-03-2013 08:00 PM
spark from spark plug! AlaskaJeepMan TJ Wrangler Technical Forum 3 08-20-2010 06:08 AM
No spark on start, one spark on run. Benny88 YJ Wrangler Technical Forum 7 03-05-2010 02:38 PM
01 4.0 No spark? Baggot TJ Wrangler Technical Forum 23 01-26-2009 12:17 AM
4.0 getting no spark, HELP Cobra Jeep YJ Wrangler Technical Forum 9 05-13-2007 06:56 PM
