No spark!!! - JeepForum.com
post #1 of 4 Old 12-21-2001, 06:21 PM Thread Starter
oilfieldtrash
No spark!!!
Ok, folks, here's my first post, just not what I wanted to start off with. I started installing my suspension lift yesterday ( '87 YJ, 258, 3.5" lift, 33-12.5's,still got more to do), needed some tunes, so I left my ignition on to play the stereo (I know, I know!) Today I finished up, slapped the tires on, and went to start her up and no joy. Checked for spark, and of course there wasn't any. I had recently installed a juice box and did the "Nutter Bypass", so I undid both of these just for kicks- still no joy. Tried manually firing the coil, still no spark. Lack of anything resembling a voltmeter forced me to "shotgun" troubleshoot; an idiot light to check for voltage, and just replacing the ignition module and pickup.
I even went so far as to run my fingers over each wire as far as I could get to check for burns, breaks, etc... Am I missing something, forgot to check anything, or am I being punished for wrenching without beer?
"What, behind the bunny?"
'87 Wrangler- 3-1/2" suspension, 1-1/2"body w/ 33's, HEI and the Nutter bypass
'83 Blazer- 8"suspension, 3" body, 35-15's and soon to get the 383!
oilfieldtrash is offline
post #2 of 4 Old 12-23-2001, 07:19 PM
Niagara_Jeep_Guy
I had a similar problem w/ my jeep. I thought that my coil was cracked and got wet or something... after replacing that it still didn't work... Anyways check the ignition module (it's a silver box w/ 4 wires located under the antifreeze overflow tank.. pain in the *** to get at.)
Niagara_Jeep_Guy
'87 YJ Wrangler 258
Niagara_Jeep_Guy is offline
post #3 of 4 Old 12-24-2001, 12:20 PM Thread Starter
oilfieldtrash
Thanks, but found it already. Turns out the ignition module AND the coil were bad. I've since rewired the stereo to come on without the ignition switch, shouldn't burn them out again.
post #4 of 4 Old 12-24-2001, 12:27 PM
glm 87 wrangler
Be carefull not to leave it on or battery will run down.But glad you got it going>Later
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
No spark during crank but spark when key released...WTF? USMC_JeepGuy YJ Wrangler Technical Forum 16 08-03-2013 09:00 PM
spark from spark plug! AlaskaJeepMan TJ Wrangler Technical Forum 3 08-20-2010 07:08 AM
No Spark... redjeepguy32 TJ Wrangler Technical Forum 3 04-08-2007 05:30 PM
new 4.0 ...no spark.help wrangler4me YJ Wrangler Technical Forum 4 04-04-2007 11:32 PM
No spark....WTF!! help please Fast Kawasaki YJ Wrangler Technical Forum 1 07-04-2006 11:21 PM
