No Spark - JeepForum.com
post #1 of 10 Old 06-15-2013, 06:51 PM Thread Starter
jjs825
No Spark
1989 wrangler 4.2l. driving home and it died on me tried pop starting it while i was coasting to a stop and nothing. towed it home and poured some fuel in the carb and nothing. checked for spark and i have no spark so i picked up a new coil still nothing. when the key is in the run position i have power to the coil terminals but nothing after that. any suggestions would be greatly appreciated. maybe its possible the new coil i picked up is defective??? it cranks over just doesnt fire up.
jjs825 is offline
post #2 of 10 Old 06-15-2013, 07:24 PM
pete1991YJ
Hi there and welcome to JeepForum, you've just found one of the best jeep sites anywhere!
I'm not real familiar with the older ignitions, yours the older Renix system while mine is the OBD-1 (computerized). But I do think that yours has an ignition control module, very similar to the old Ford Duraspark boxes. And they say that it burns out often. Might want to have a look at that or wait for somebody with another 1989 with the 4.2.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #3 of 10 Old 06-15-2013, 07:38 PM Thread Starter
jjs825
I was actually looking for it today couldnt seem to locate it. i planned on starting there in the am but figured id put up a post hopeful avoid just throwing money at it. thanks for the input.
jjs825 is offline
post #4 of 10 Old 06-15-2013, 08:14 PM
dancytron
The ICM is underneath the washer fluid and overflow coolant tanks. Take them out and it will be right there.
It could very easily be your problem.
dancytron is offline
post #5 of 10 Old 06-15-2013, 08:22 PM Thread Starter
jjs825
Awesome!! thanks alot
jjs825 is offline
post #6 of 10 Old 06-15-2013, 08:51 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I am vaguely familiar with the old Renix system. I owned an '88 Grand Cherokee years ago. It had a TDC sensor IIRC which is what we now call a crank sensor. If it goes bad you probably don't get any spark (or fuel?) either since the ECM gets no report of flywheel movement so the ECM sends no signal to the ICM which in turn won't fire the coil.
The ICM may very well be the problem. But if you swap it out and it still won't fire I would check the TDC sensor next. It is mounted on the left side of your bell housing much like the cranks sensor is nowadays.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #7 of 10 Old 06-15-2013, 10:34 PM
dancytron
It doesn't have a TDC sensor or a crank sensor.
post #8 of 10 Old 06-15-2013, 11:28 PM
jokerchief462
OK my bad here it is the troubleshooting charts from the FSM for bot the 4.0 and 4.2. This for no spark won't start problem. 7 pages long hope you can use this and follow it. Best I got.
Ign 89 4 #1.jpg   Ign 89 4.2 #2.jpg   Ign 89 4.2 #3.jpg   Ign 89 4.2 #4.jpg   Ign 89 4.2 #5.jpg
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #9 of 10 Old 06-16-2013, 05:21 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
You're right! Maybe it was only the 2.5's. They had FI not a carb.
EDIT YET AGAIN. I think there was a 4.0 in the 1989 Jeep Cherokee Wagoneers and it had MPFI.
post #10 of 10 Old 06-16-2013, 12:47 PM
rogerv
Have you found anything yet ? Just out of curiosity what carb are you running ? Did you get the ICM checked to see if it's working properly ?
My last ICM lasted 10 months- switched it over to the GM style. I like $28 better than the $70 advanced auto wants.
I can send photos if you like,
If it's not broke- modify it, so it won't break
rogerv is offline
