No spark - JeepForum.com
post #1 of 3 Old 03-28-2010, 07:06 AM Thread Starter
osmondmark
No spark
My 1992 Jeep YJ 2.5L will not start. I checked for spark and the plugs and there is none. I also took a test light and checked for power before and after the coil while cranking the engine and there is none there either.
I tried to use the check engine light to get some codes but the light doesn't even come on. As well I cannot hear the fuel pump cycle when the key is first turned on.
I was told by this forum to take the computer apart and check to see if there is anything there and I never noticed anything besides minor corrosion on top of one of the compactors. I mean like maybe 35% covered.
I cant get a mechanic to come take a look at it so I am stuck figuring this one out on my own.
Any help would be great!
Thanks a lot.
osmondmark is offline
post #2 of 3 Old 04-03-2010, 12:03 PM
teaser73
I was going down the road and my jeep died on the spot. I had no spark and no code light. My fuel pump would not kick on when I turned the key. I replaced the cam position sensor in the distributor and the crankshaft position sensor on the bell housing. I still had no luck. It turned out to be a corroded ground wire to the computer. I hope that fixes you up.
Due to recent budget cuts, high unemployment and the rising costs of food, electricity, gas and oil, as well as current market conditions, and the overall state of the union, The Light at the End of the Tunnel has been turned off. We apologize for the inconvenience.
teaser73 is offline
post #3 of 3 Old 04-03-2010, 12:05 PM
Que89YJ
Check all your fuses if they are good then X2 cranksensor.
Que89YJ is offline
No spark during crank but spark when key released...WTF? USMC_JeepGuy YJ Wrangler Technical Forum 16 08-03-2013 09:00 PM
spark from spark plug! AlaskaJeepMan TJ Wrangler Technical Forum 3 08-20-2010 07:08 AM
No spark on start, one spark on run. Benny88 YJ Wrangler Technical Forum 7 03-05-2010 03:38 PM
A spark now nothing provinT13 YJ Wrangler Technical Forum 5 06-15-2008 09:24 PM
No Spark Provojeep YJ Wrangler Technical Forum 8 10-31-2007 10:57 PM
