No power going into coil - JeepForum.com
post #1 of 13 Old 11-23-2011, 01:03 PM Thread Starter
jeepcrazy93
I am trying to finish up my 4.0 swap for my 93. I had the jeep running but a few days ago I tried starting it and the motor turns over but no spark. I have no spark after the coil or power going into coil. I have replaced the cps (crank), cps (cam), coil. I even linked 87 and 30 together on the ASD relay. I am getting fuel but no spark. I tried to pull the codes and I am getting a few codes. I think the one code is 53. I tried the search feature but nothing that fits my description.
93 YJ 4.0 AX-15 33's 8.8 with CJ front clip
03 F-250 Extended Cab Long Bed with 7.3
jeepcrazy93 is offline
post #2 of 13 Old 11-23-2011, 07:49 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
The power for the coil comes from your ASD relay which I think is in the PDC. The PCM feed is the ground circuit which shuts off/turns on the ground to the coil.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 13 Old 11-24-2011, 03:14 PM Thread Starter
jeepcrazy93
I'm thinking about checking the new crank sensor to see if its bad.
post #4 of 13 Old 11-24-2011, 04:56 PM
Mark05059
gotta have power at the coil before the sensor fires it... check the asd relay
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 13 Old 11-24-2011, 05:56 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
If the PCM gets a movement signal from the crank sensor you get fuel and spark unless something else prevents one from happening.
I would check for the ground pulse at the PCM that goes to the coil. If the ground pulse is there then the problem is the wiring from that point to the coil.
If the ground pulse is getting to the coil then the problem is no power getting to the coil from the ASD relay. Or the coil is junk.
post #6 of 13 Old 11-24-2011, 06:20 PM
Noltz
YJ Wrangler
Yep as mentioned you get constant power from the ASD relay, mounted in the PDC. The ECM is responsible to keep the relay grounded ("ON") when appropriate.
It sounds like you have a break in the wiring, since the fuel pump also is powered from the ASD. You can confirm this is your only issue if you can supply fused power to the coil and then try to start the Jeep. The ECU supplies the ground to the coil, and breaks that ground signal to create the spark when needed.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #7 of 13 Old 11-25-2011, 07:16 AM Thread Starter
jeepcrazy93
Thanks guys. Ill check it out next time I get a chance.
post #8 of 13 Old 11-29-2011, 02:27 PM Thread Starter
jeepcrazy93
I put a new ASD relay in and still nothing. I so I did what Noltz and added fused power wire to the coil and then I got spark. I need to readjust my timing but at least I have spark. Thank you guys.
post #9 of 13 Old 11-29-2011, 06:10 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
So you bypassed the coil wiring from the ASD relay but you should try to find the problem, OR you end up with a rig that is nothing but gerry rigs!. Trace the coil wire at the coil back to the ASD relay or test that wire for continuity. I believe it goes to a splice. It could be bad at the splice.
post #10 of 13 Old 11-29-2011, 07:57 PM Thread Starter
jeepcrazy93
You are exactly right. I will be fixing it but i used that bypass to help me diagnose the problem.
post #11 of 13 Old 09-09-2016, 11:37 AM
erond98
93 yj
i have pulsing signal at coil of 93 4.0 but no constant 12 volt when plugged in,needless to say seems odd.
erond98 is offline
post #12 of 13 Old 09-09-2016, 12:18 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Hi erond98. This thread is rather old and the only people seeing it are the OP and just the few of us that responded.
Give everyone these detailsFill out your profile) but in the meantime what year YJ? engine? transmission? modifications?
Then post what your problem is and any symptoms you are having. You will surely get someone to get back to you. Welcome to the JF!!
http://www.jeepforum.com/forum/f12/
post #13 of 13 Old 09-10-2016, 09:09 AM
erond98
1993 yj,it's a 4.0 liter engine with automatic,its all stock with a yellow spark from coil and thin stream shoots from injectors,not a mist like you would think.also thanks for where to put this on forum.
erond98 is offline
95 YJ 4.0 No power to the coil crashdnt YJ Wrangler Technical Forum 7 03-14-2011 09:39 AM
how does the icm know when to sent power to the coil? vicker YJ Wrangler Technical Forum 2 09-30-2010 02:45 AM
power to the coil question wvcracker YJ Wrangler Technical Forum 2 06-02-2010 06:34 PM
Power going to coil Mikerp97 YJ Wrangler Technical Forum 6 12-02-2009 08:09 AM
power to the coil raysnutt18 TJ Wrangler Technical Forum 3 12-03-2007 03:18 PM
