No power at the coil. - JeepForum.com
post #1 of 8 Old 02-17-2013, 09:20 AM Thread Starter
redbird555
Hey guys the other day out of nowhere my 95 i4 wouldn't start. I've verified that the injectors get power with the key on, the fuel pump primes I just have no power at the coil plug. The distributor and crank sensor has been recently replaced and seem to check out fine I'm going to pull the PCM and verify I have a coil signal. But does anyone have ideas??
redbird555 is offline
post #2 of 8 Old 02-17-2013, 10:35 AM
Mark05059
turn the key to on and watch for a check engine light. It should come on and go off in a few seconds.If it does then the following is not your problem. If it doesnt come on just leave the key in the on position and wait (might be up to a couple of minutes). IOnce the light comes on (you probably will hear a bunch of clicking too) start the jeep.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 8 Old 02-17-2013, 12:13 PM Thread Starter
redbird555
yep if i turn the key on i get the normal check engine light and after a few secs it goes off. I kept checking wires and I think i have arrived at the fact the pcm is bad. the asd is supplying power to the pump and thus the coil but I have no power there, i have power at the ignition fuse on the blcok also. I also checked the crank sensor harness coming from the pcm and at the sensor and realized no matter what I do there is no power in the harness.
post #4 of 8 Old 02-17-2013, 03:45 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Unplug the VSS sensor on your transfer case and see if it starts.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 8 Old 02-17-2013, 05:53 PM
Mark05059
might also have to follow wires from the coil back
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #6 of 8 Old 02-17-2013, 06:50 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Check your diagnostic codes. Here are the links on how to do it in the FAQs section. It could be your CPS(crank position sensor).
http://www.jeepforum.com/forum/f12/f...54/#post682627
http://www.jeepforum.com/forum/f12/f...54/#post682636
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #7 of 8 Old 02-17-2013, 07:45 PM
mike_breaker_5
ASD relay?
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #8 of 8 Old 02-18-2013, 07:09 AM
Que89YJ
You are not reading the coil power correctly(Maybe). You need to read with one side to the coil and the other to ground on the chasis. You cant read across the coil to check power.
Que89YJ is offline
