No power? Cant accelerate after 2nd gear... - JeepForum.com
post #1 of 16 Old 10-12-2013, 08:09 PM Thread Starter
racoonfrenzy
Im having issues with the jeep not being able to accelerate...
1st gear I get to about 3500 rpm and shift, 2nd gear 3500rpm shift, 3rd gear bogs down at 2000rpm and wont pick up unless going down hill...
Shifting as soon as the shift up light comes on...
Im in 2hi as far as I can tell. What the heck is going on?
No check engine light...
racoonfrenzy is offline
post #2 of 16 Old 10-12-2013, 08:15 PM
Ohsplat
Check fuel pressure.
Ohsplat is offline
post #3 of 16 Old 10-12-2013, 10:47 PM Thread Starter
racoonfrenzy
I don't have a psi guage until I can rent one from autozone, however I turned the key to prime the fuel pump and went up to the fuel rail and hit the needle-valve. Nothing comes out, is that normal? No pressure before starting the vehicle?
post #4 of 16 Old 10-12-2013, 11:04 PM
Ohsplat
If it primed, it should have pressure. Try priming it 3 or 4 times, if you dont get anything from bleeder its a fuel problem. You can also hit the bleeder after you run it. If I turn off engine and hit bleeder it shoots as high as the hood.
Ohsplat is offline
post #5 of 16 Old 10-12-2013, 11:09 PM
MoparMech
1995 XJ Cherokee
If you find that you have fuel pressure. Pull out one of your o2 sensors before the cat and see if it runs better. A plugged cat will Kill your power.
MoparMech is offline
post #6 of 16 Old 10-12-2013, 11:12 PM Thread Starter
racoonfrenzy
Just rebuilt the exhaust, no cat, and new muffler...
Turned the key to on 3-4 times heard the fuel pump whine. No spray.
Started it up, shut it off. Not even a dribble...
How is it managing to even drive if it has no fuel pressure? lol
post #7 of 16 Old 10-13-2013, 02:58 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Great Question:
There could be a few reasons it starts and runs while seeming to have no pressure. It may be that you have pressure while priming and running, but your Fuel injector(s) have bad o-rings and it bleeds the pressure out quicker than it should.
The question I would be asking myself is - When did this issue start to happen, and what did I do just before it started?
If you just removed the cat, and made changes to the exhaust, what else did you do? Possible the O2 sensor got borked during the changes?
If it's not presenting the CEL, did you try to get codes off the ECM? If so, what codes did you get?
Let's start with the codes.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #8 of 16 Old 10-13-2013, 05:41 AM
WDNewman
Your upshift light comes on at 3500 RPM?? Wow.
WDNewman is offline
post #9 of 16 Old 10-13-2013, 12:54 PM Thread Starter
racoonfrenzy
No, but if I dont shift at 3500 I don't have enough power to keep going in the next gear
I just got the jeep a couple days ago, the PO had the exhaust cut off behind the muffler and it ran like crap before that too. It was just so loud that I figured that I was shifting too low of rpm...
I do get CEL codes ; 12,33 but those don't pertain to anything that would cause this... just A/C relay - I dont have A/C
Now if the injectors were leaking would I see an initial spike in psi, the see it drain to 0?
post #10 of 16 Old 10-13-2013, 01:33 PM Thread Starter
racoonfrenzy
At prime it goes to 8psi then to 0psi in about 1-2 seconds.
I start the car it goes to 30psi, rev the car it goes up to 32psi
As soon as I turn the car off it drops to 0psi...
post #11 of 16 Old 10-13-2013, 02:51 PM
Luuca
Luuca's Avatar
At prime it goes to 8psi then to 0psi in about 1-2 seconds. I start the car it goes to 30psi, rev the car it goes up to 32psi As soon as I turn the car off it drops to 0psi...
You are running low fuel pressures. If you are near a junkyard with Cherokees, they use the same Fuel Pressure Sensors as ours do. Take an 8mm socket and go grab the FPS, the bolt, the metal clamp, and the vacuum line ( if there) and swap it out. Just make sure the FPS you pull has fuel in it when pulled. Most do, the ones without are less likely to work. Bottom of the tool bag, price o admission odds and ends that may fix your issue.
Posted via my pretentious iPhone.
YJOTM Sept. 2017
Luuca is offline
post #12 of 16 Old 10-13-2013, 03:58 PM
nzpete
You should have had pressure to push some fuel out. Get a pressure tester to make sure.
HF has a decent one for sale for 20 bucks. A good tool to have.
http://www.harborfreight.com/fuel-in...ter-92699.html
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
post #13 of 16 Old 10-13-2013, 08:22 PM
Ohsplat
Ever replace the fuel filter? The regulatore or fps is a idea but a bad injector or bad check valve in the fuel pump can cause drop off to. Get a mechanics stethoscope and listen for the clicks on each injector. To test the fps you can clamp the plastic fuel return line and see if it runs better. WARNING don't run it that way long. Clamping that return line will let u know if its the fps. If you clamp it and fuel pressure raises bingo its your fuel pressure regulator (fps).
Ohsplat is offline
post #14 of 16 Old 10-14-2013, 09:37 PM Thread Starter
racoonfrenzy
I replaced all the spark plugs including the hard the reach rear one. I don't think that one was sparking at all.
I took the vacuum line off the regulator and it goes to 43psi which seems to be within spec. It looks like the check valve is bad on the fuel pump so its not holding pressure when you prime it. But after changing that last spark plug it has seemed to pick up a little power.
Ill be replacing the fuel pump this weekend so hopefully that will clear up the issue entirely.
post #15 of 16 Old 10-15-2013, 02:20 PM
Ohsplat
Let us know even if it helps. A lot of people tend not to reply to what the fix was.
Ohsplat is offline
