No power anywhere - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > No power anywhere
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-07-2015, 12:29 PM   #1
07tjt07
No power anywhere
Went to start the 90 2.5 Jeep this morning, and the seatbelt buzzer came on for half a second, but then shut off. Since then there has been no power anywhere. The battery read 12 volts and its only 3 months old. Lights were off. Now nothing comes on. I need Que!
07tjt07 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 01:05 PM   #2
Anticanman
RIP one good jeeper
Anticanman's Avatar
Fuses? Did you check the connections at the battery since they may be loose from installing it recently? It never hurts to double check things like that.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 01:12 PM   #3
Que89YJ
90, fusible links. PM sent
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 05-07-2015, 01:26 PM   #4
07tjt07
PM received! I'l call in a few, thanks!
