No Power - Page 2 - JeepForum.com
post #16 of 26 Old 04-10-2010, 08:51 PM Thread Starter
disarm6565
I jumped the battery to the body with some jumper cables, still nothing. I have power at my alternator and starter.
1993 4.0 AX-15
disarm6565 is offline
post #17 of 26 Old 04-14-2010, 11:40 AM Thread Starter
disarm6565
So when I was under the hood looking at the PDC, I am definitely missing the fuel pump relay (and the abs relay but no abs) I know the abs relay was NEVER there. Is it possible someone stole my fuel pump relay? could this cause the whole jeep not to have power?
1993 4.0 AX-15
post #18 of 26 Old 04-14-2010, 12:26 PM
ziebartrob
Have you checked that main ground yet? Really sounds like a central sort of problem like that since you have no power at all.
Originally Posted by Mymmars
when your start to anthropomorphise your jeep into somthing above a dog and below a hooker
ziebartrob is offline
post #19 of 26 Old 04-14-2010, 12:30 PM Thread Starter
disarm6565
By main ground I assume you mean the black wire from my battery to the engine block? That was the first thing I replaced. I really don't think I'm getting any power to the PDC.
1993 4.0 AX-15
post #20 of 26 Old 04-14-2010, 12:34 PM
ziebartrob
Sorry, I missed that. There is red batter cable size hot going to the PDC, on my 91 the cable was almost broke in half at the terminal ring causing similiar issues. Might give that a check as well.
post #21 of 26 Old 04-14-2010, 01:28 PM
RebuildRookie
You said you couldnt hear the fuel pump kick on? Well it wont, as your probably already aware, without the Fuel Pump Relay. Start there and see what happens. Since you know for sure that is a problem.
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #22 of 26 Old 04-14-2010, 01:29 PM
RebuildRookie
How about the block to the firewall?
post #23 of 26 Old 04-14-2010, 03:16 PM
monkeyhouse
Drove to work on Thursday, got back to the Jeep after work and it has no power. I tried to pop start it, nothing. I tried to jump it, nothing. I replaced the battery and terminal cables, nothing. All fuses look fine. Starter/solenoid about a year old. Oh and by no power I don't mean it won't start, I mean there is absolutely no power anywhere.
I have to say, it would be fairly easy to go through and clean the grounds up and costs nothing. I thought though that if you have no lights when you turn the key that indicated a computer problem?
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #24 of 26 Old 04-14-2010, 04:23 PM Thread Starter
disarm6565
I just don't understand how a fuel pump relay goes missing. I really don't think I ever had one there because I seem to remember always missing two relays. I really can't remember. Does anyone else definitely not have theirs?
The ground to the firewall is also fine, I even tried to jump it with a jumper cable to check.
1993 4.0 AX-15
post #25 of 26 Old 04-14-2010, 07:31 PM Thread Starter
disarm6565
So, I'm well...oblivious. The missing relay belonged to the ABS pump, not the fuel pump. I don't have ABS so no issue there. All the wire going into the PDC look good. I was told by someone that there should be a main fuse that powers everything (they guy at NAPA pointed to a fuseable link but couldn't find it in the computer so I'm not sure it exists) Anyone know anything about this? Supposedly its a fuse that blows if you hook up the battery wrong to protect everything else in the circuit.
1993 4.0 AX-15
post #26 of 26 Old 04-18-2010, 07:13 PM Thread Starter
disarm6565
Found my problem, check out this thread:
http://www.jeepforum.com/forum/f12/c...ything-923863/
I jumped a wire straight from my battery to that the terminal on the PDC and everything works. Now I just gotta find out what happened to that wire because it is definitely not there.
1993 4.0 AX-15
HUGE problem with '87 4.2L - Ignition Switch Power Issues (No power on key turn) jesseleikerjeep YJ Wrangler Technical Forum 11 02-26-2016 04:25 PM
New tires, rims and power wow no power! asuperheat JK Wrangler Technical Forum 40 10-11-2010 06:54 AM
winch question- what is power in/power out capabillity staquinas TJ Wrangler Technical Forum 1 08-04-2009 05:44 PM
ARB Compressor Power Source / Wiper Motor Power Wire Color? Lawdodge TJ Wrangler Technical Forum 4 06-28-2008 10:42 AM
Power Door Locks and Power Windows JurassicMan JK Wrangler Technical Forum 8 07-12-2006 09:14 AM
