No one has been able to help me yet..... - JeepForum.com
post #1 of 13 Old 05-27-2013, 06:50 PM Thread Starter
bluedevil4
https://www.youtube.com/watch?v=QV7ziIGLbbo
This is a video of my 1991 Jeep Wrangler YJ with the 2.5L engine, manual transmission. This is how my problem started:
I was doing about 65 down the interstate. Once I hit the off-ramp, my Jeep gave out. I was able to start it back up, but it started to run differently. When I would reach higher rpms (3000-3500) it would start to make a sort of grinding sound. A week or so later, I had my son press the gas a little while I was under it to check something. He pressed a little too hard and it just quit and it hasn't started since. The video shows what my Jeep is doing. Now, on to what I have done to it to try to fix the problem.
- New battery
- New battery cables
- New starter
- New rotor button
- New crankshaft sensor
- New spark plugs
Please, any help would be awesome. No one has been able to help me so far. Thanks in advance.
-Brad D.
bluedevil4 is offline
post #2 of 13 Old 05-27-2013, 07:01 PM
rykemc
Had problem loading the video but you might want to check and see if the timing jumped or not. That would be the timing chain.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #3 of 13 Old 05-27-2013, 08:18 PM
superj
Video is a no-go
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 13 Old 05-27-2013, 08:20 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Didn't work here either.
Are you throwing any codes?
Luck Favours The Prepared
Anticanman is offline
post #5 of 13 Old 05-27-2013, 08:23 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Video is set to 'private'.
YJOTM JULY 2014
DirtKar is offline
post #6 of 13 Old 05-27-2013, 08:24 PM
Reno72
Video didn't work. Have you checked for a spark at the plugs? If not, that is where I would start and work back. If you have good spark at the plugs go to the fuel starting at the carb and working back.
Reno72 is offline
post #7 of 13 Old 05-27-2013, 08:54 PM Thread Starter
bluedevil4
Sorry, I fixed the video. I do have spark and I do have fuel to my fuel rails.
post #8 of 13 Old 05-28-2013, 07:01 AM
Que89YJ
It sounds like the timing jumped. Pull your timing chain cover and check your chain or you can do it old school and see how much slack you have by using a wrench on the crank shaft pulley. Pull the distributor cap and move the crank until the rotor starts to spin in the distributor. Spin it in the opposite direction and the difference is the amount of slack in the chain. You shouldnt be able to move it more then a 1/4". If you can then your chain was loose and its the timing chain.
Que89YJ is online now
post #9 of 13 Old 05-28-2013, 10:19 AM
superj
dude, your battery is almost dead.
superj is offline
post #10 of 13 Old 05-28-2013, 03:49 PM
idaholtby
^^ agree with this scenario. I can hear the soft, hallowed "poofing" sound in your vid while cranking that occurs when the valve train is not sealed on compression. Especially given that this happened while going onto an off ramp. A slack timing chain will easily jump on deceleration.
idaholtby is offline
post #11 of 13 Old 05-29-2013, 08:43 PM
bowtech
Start with the timing chain. Pretty sure that will be the culprit. As mentioned they love to jump on deceleration.
bowtech is offline
post #12 of 13 Old 05-30-2013, 09:51 AM
Siva283
After timing check for fuel and spark. If you have both it may be time for a compression test. Assuming it isnt one of the prior 3
Ask me how I know...
Siva283 is offline
post #13 of 13 Old 05-30-2013, 06:43 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Where did you buy the new CPS? They have been known to be bad out of the box. Check your codes. There's a section in the FAQs to tell you how to do it.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
