#1 | |
No Heat
The blower for heat and air in my jeep works just fine and i get a good flow of air but when i turn the heat on it still just blows cold air. any thoughts on this? would it be a bad heater core? or maybe no coolant flow to the core?
'93 YJ SOA 44/60, 38 SX's, H1's Build Thread:http://www.jeepforum.com/forum/f12/project-project-578313/ Dana 35 Disc Brake swap |
#2 |
sounds like the heater core. try doing a flush of just that. do it forward and reversed. use a garden hose or take it to the carwash. just dont squeeze the trigger, it has to much pressure and will destroy it.
1990 Jeep Wrangler YJ 2.5 2004 Grand Cherokee Special Edition 2010 Ford F150 FX4 Welcome to America, now speak English! |
#3 | |
Jello Puddin'
I'd venture to say the heater core, but maybe the thermostat as well. May try that first as they're cheap and way easier to change out than the core.
#4 |
Also check the actuator cable that open/close the door to the heater box; if disconnected, it blows cold air no matter what!
#5 | |
Right. Make the the rod below the dash on the passengers side is connected to the loop. |
#6 |
Check/do the following in order..
1) If the engine temp doesn't come up to about 180-210 then you have a bad thermostat. Replace with a 195 degree thermostat. 2) Check the temp of the two heater hoses with the Jeep running, up to temperature and the heater blasting. If both hoses are cool or 1 hose is cool then you have a blocked heater core (or less likely a blocked hose). If both hoses are hot then you have a problem with the temp controll to blend door connection or operation. |
#7 | |
Smart Feller!
'91 YJ, 4.0, 5sp, D30/8.8 w/4.56's locked F&R, ProComp 4.5" SUA on 37x12.50x15 Super Swampers, 3"BL |
#8 |
I just had the issue on my 95 bought a heat core for $35.00 @ Pepboys now It works awesome!
#9 |
Just finished flush
Had the same issue on my 90 YJ. Took heater core hoses loose from the engine and used garden hose to flush. Gunk went everywhere. Flushed until the water ran clear. Connected the hoses and have a heater that will cook an egg now..
JJ Jeep |
#10 |
T00L....
To perhaps clarify what JJ mentioned: It sounds like he disconnected the hoses at the ENGINE side - NOT at the firewall
Meaning that you had the benefit of the hoses to work with and were not twisted up against the firewall trying to force the hose into the core tube. ![]() |
#11 | |
I'm tired
Even better would be to look for a radiator flush kit and hook it into the disconnected hoses. That way you have a connection to twist the hose into.
The Final Salute EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun! We've idiot proofed the world... now its full of idiots. - Spiritof76 You will truly be the same today as you will be five years from now, except for two things... ...the people you meet and the books you read. Charles E. Jones |
#12 | ||
Jello Puddin'
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
