no gas when starting - JeepForum.com
post #1 of 3 Old 11-12-2001, 09:48 AM Thread Starter
jmsjeep
My jeep is not getting any gas when I turn the key. I hear the fuel pump come on and no stalling when running. Once it starts (from me pumping the gas pedal) its fine. I have a T.B.I injection system. What is supposed to be getting the gas going with the turn of the key. Is my injection shot?
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #2 of 3 Old 11-13-2001, 05:49 AM
Ruftags
When was the last time you changed the fuel filter. The other thing is inside the throttle body behind the butterfly all the grit can turn into this kind of grimmy varnish type crap. If you take the throttle body off and give it a good cleaning with some carb and choke cleaner and soft brissle brush. Be careful, but you'll notice a world of difference after.
95 YJ 2.5L AX5 30in. rubber.
So many upgrades/So little cash!!
Ruftags is offline
post #3 of 3 Old 11-13-2001, 09:40 AM Thread Starter
jmsjeep
thank you I will try that this weekend.
If this is whats wrong wouldn't cause a loss of gas occasionally while driving or at idle?
My valve cover is leaking and my injector is covered with oil, could that be effecting anything?
jmsjeep is offline
Starting Help TJoeT TJ Wrangler Technical Forum 4 04-06-2009 06:51 PM
Not starting schatenjager YJ Wrangler Technical Forum 9 04-23-2008 04:02 PM
Doesn't like starting NewdRiver_ YJ Wrangler Technical Forum 3 02-20-2008 12:46 AM
Help On Starting!!! xpanterax YJ Wrangler Technical Forum 12 12-04-2006 08:04 PM
Starting in 2nd... NJwrangler TJ Wrangler Technical Forum 24 11-27-2006 08:42 AM
