no fuel on start up! HELP ME!!! - JeepForum.com
post #1 of 9 Old 12-26-2010, 10:43 AM Thread Starter
95mudman
95 yj 160k 4cyl having a hard time starting.
so im cranking the **** out of my jeep to get it running. eventually it will turn over but im not hearing the pump purge which i think it normally does when i turn the key forward. ive tried to turn the key on and off a few times but nothing is working. once its up and running and i shut id down for a few mins it will start right bakc up but if it sits for more then an hour it will not start. its as if its not pumping or the fuels backing out of the line somehow. i have a feeling the pump is shot but on the other hand once it starts up and i drive it fine. so do i need a new pump or is it something else? i did replace this pump less then a year ago but hey from offroading it could be shot again. please help me! thanks
95mudman is offline
post #2 of 9 Old 12-26-2010, 11:31 AM
Mywrangler94
I've had this happen twice. One was the fuel pump, the other was the relay. Check your wiring its fairly easy....they run down the frame on the drivers side. Turn your key on see if the pump has power immediately. Secondly see if you have pulse at the injectors...(make sure they are firing). If all is well I would change the fuel pump. Don't forget...if you have a leaky injector, it will let the fuel pressure drop as it sits....let us know...
Mywrangler94 is offline
post #3 of 9 Old 12-26-2010, 12:18 PM
MJMPC
Does your CEL come on when you turn the key on?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 9 Old 12-29-2010, 05:17 PM Thread Starter
95mudman
so i am assuming my issue may be electrical...if i get the jeep to fire up then i shut it down the pump turns on right away. however if i let the jeep sit for like 20mins or more then turn the key to on i will not hear the pump purge the lines. if i leave the key in the on position for a few mins the pump will then purge but under the hood im hearing a very loud clicking noise as if my battery just died kinda noise. i just replaced the pump and that didnt solve my issue what so ever. it was under warrenty so no biggie. i just cant figure out what the hell the problem could be that it wont start if it sits for a while. this got so bad that it wouldnt start at all. HELLLLP ME!!!
95mudman is offline
post #5 of 9 Old 12-29-2010, 06:14 PM
Mark05059
do a search on long cranking when cold. I think your experiencing the problems many people have had with the capacitors in the ECM. There is a thread on how to diagnose this problem here on the board. Im sure if you search for it you will find it. They are not that expensive to change.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 9 Old 12-29-2010, 06:29 PM
MJMPC
This might help.
http://www.jeepforum.com/forum/f12/9...lained-490788/
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #7 of 9 Old 12-29-2010, 07:02 PM
Mark05059
Originally Posted by MJMPC View Post
thanks MJMPC I was just wrapping up work and was on the way out the door. Thanks for posting the link I was looking for.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #8 of 9 Old 12-30-2010, 05:04 AM Thread Starter
95mudman
thanks guys this def seems like my problem so far. ugh i dont even wanna deal with this anymore haha. i just went through all of this less then a year ago.
95mudman is offline
post #9 of 9 Old 12-30-2010, 07:01 AM
Que89YJ
Mjmpc no cel question x 2. No cel then search for ecu brain surgery. It sounds like bad caps.
Que89YJ is offline
fuel , gas , pump , regulator , YJ
87 tj hard to start/fuel ? hurstjeep YJ Wrangler Technical Forum 2 09-13-2009 03:15 PM
No spark No fuel No start Mark05059 YJ Wrangler Technical Forum 9 07-05-2009 07:39 PM
97 TJ 4.0 won't start (fuel pump?) mbuna TJ Wrangler Technical Forum 28 04-01-2007 09:22 PM
2000 4.0 no start - no fuel mp3coupe TJ Wrangler Technical Forum 1 04-16-2006 02:43 PM
got fuel, got spark, but it still won't start?? jfallken TJ Wrangler Technical Forum 25 03-28-2005 04:25 PM
