no fuel after weber installed - JeepForum.com
post #1 of 4 Old 02-25-2012, 09:06 PM Thread Starter
bluedaffy
I just installed my brand new weber 32/36 today and hooked everything up (I believe correctly) but I have not yet nuttered it. I DO plan on nuttering it tomorrow. I tried to start it after swapping the carbs, and it did not start, this did not concern me very much because I have a lot of vac line stripping and nuttering to do before the weber will perform correctly... I know this. What concerned me was the carb wasn't receiving fuel AT ALL, I will be installing a fuel regulator before I start driving in the spring but that shouldn't keep the carb dry when trying to start should it?
I seriously don't understand this at all. There was no sign of any fuel delivery problem before I swapped carbs. And believe me I turned it over a lot trying to start it, I def gave it enough time. What's the deal? What would keep even a drop of fuel from getting to the carb?
bluedaffy is offline
post #2 of 4 Old 02-25-2012, 10:11 PM
4.7stroker
You should not need a FPR, just keep the return style fuel filter. You will not over pressure with it and it will keep a variable out of the system.
As far as no fuel goes, are you sure you have the supply and not the fuel return hooked up to the carb?
Will it fire if you give it a little squirt of gas down the throat of the carb?
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 4 Old 02-26-2012, 06:17 PM Thread Starter
bluedaffy
Fixed. I took your advice and put a bit of fuel down the throat, it was all it needed! It ran like Sh** but I expected that until I finish the nutter. Thanks
post #4 of 4 Old 02-26-2012, 06:23 PM
monkeyhouse
well, I was gonna mention there may be no fuel in the lines(at least close to the carb) from doing the swap. When I was doing my swap, I kept a can of starter fluid close by. Definitely helpful. Glad you got it figured out though.
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
carb , fuel , fuel problem , swap
Installing weber 34 carb, Fuel pressure reg installed rustywrangler YJ Wrangler Technical Forum 57 04-27-2009 01:21 PM
finally installed the weber NJscott YJ Wrangler Technical Forum 12 03-30-2008 07:58 PM
Weber installed 05LjNj YJ Wrangler Technical Forum 10 06-25-2007 04:28 PM
Just installed the Weber! Charlie L YJ Wrangler Technical Forum 2 05-18-2002 07:40 PM
New Weber Carb installed!! Mikein YJ Wrangler Technical Forum 0 08-29-2001 07:33 PM
