No fire, No start? - Page 2 - JeepForum.com
post #16 of 20 Old 11-07-2013, 07:16 PM
Que89YJ
41 is alt. Field. What about coil voltage with ign. on?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #17 of 20 Old 11-09-2013, 08:43 AM Thread Starter
Goat7
Ok so i was getting no power at all from the coil after all the tests. A friend of mine is a jeep guy and he said he had an extra cam pos sensor and i tried it and BOOM she started hahah i cant believe a part like that shut everything down hahaha. She started but is running full rich so i gues im onto the next problem haha thanks for all the help it amazes me how good you guys are with this stuff. Thanks again for the help
Goat7 is offline
post #18 of 20 Old 11-09-2013, 08:54 AM
Que89YJ
That was the crank sensor wasn't it? Running rich is a cracked exhaust manifold, bad o2 sensor, our fuel pressure too high.
Fault codes:
No Start:
Que89YJ is offline
post #19 of 20 Old 11-09-2013, 09:01 AM Thread Starter
Goat7
No it is the sensor in the distributer cap i woukd normally call it a pick up coil but im not sure what it is actually called hahaha. Any checks for that 02 sensor ot should i just get a new one?
Goat7 is offline
post #20 of 20 Old 11-09-2013, 11:40 AM
Que89YJ
The first thing to check is the exhaust manifold by the collector tubes for cracks and the bolts on the manifold especially the ones close to the firewall. Since you have done the mechanic thing I know you have a pressure guage. Check the rail pressure. 31psi idle, 39 psi with the vacuum line to the regulator on the fuel rail disconnected & stays above 20 psi for 20 minutes after key off.
Fault codes:
No Start:
Que89YJ is offline
