No fifth gear in 93 yj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > No fifth gear in 93 yj
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-01-2014, 06:06 AM   #1
cff36
Going from 4 to 5 and it was like putting it in neutral I'm thinking it must be some kind of issue with the top of the tranny fork ect. As when it went into where fifth should be there was no sound as in gears grinding or banging any info would help its a 4 banger so not sure what tranny it is thanks
cff36 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 06:33 AM   #2
CjinPA
CjinPA's Avatar
The transmission is an AX5. There is a retaining clip that holds the fifth gear in place. It is a common issue for the clip to break and for the gear to move back on the main shaft it the transmission. You should be able to run it like that but you will not have 5th gear until someone pulls the trans apart and puts a new retaining clip in.
84 CJ7 Northstar V8
91 YJ Renegade, I have owned it since it was new.
Jeeps that I am currently parting out;
199 Jeep TJ 4cyl 5spd
1988 Jeep YJ 6cyl 5spd
1984 Jeep CJ7 6cyl 4spd
CjinPA is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 06:47 AM   #3
captainauti
captainauti's Avatar
http://www.jeepforum.com/forum/f12/a...emoval-908252/
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is online now   Reply With Quote Quick reply to this message
Unread 10-02-2014, 01:35 PM   #4
oakescharles
2015 JK Wrangler
What's 5th Gear? (says a man with a 2.5 and 35's)
oakescharles is offline   Reply With Quote Quick reply to this message
Unread 10-04-2014, 07:30 PM   #5
cff36
Update splines inside 5th gone splines on shaft gone found a beater using that tranny instead 1 more day and should be back on road
