No electrical, Jeep dead, please help!!!! - JeepForum.com
post #1 of 12 Old 08-08-2011, 05:22 AM Thread Starter
UMDJesse
I have a 92 wrangler 4.0 6cyl with 5 speed, 200,000 miles on it and it just died.
I have no electrical, wont turn over, no lights. If I put on the hazard I can hear the relay click but no lights. The parking brake light on the dash lights up but VERY faint.
What I have tried:
-New battery...nothing, still worn turn over, no power.
-Check ALL grounds....All grounds, checked cleaned, retightened, tested resistance, all are good. Still does nothing to fix the issues.
-Look for shorts. I could find no obvious shorts. NO FUSES ARE POPPED, which leads me to believe further that a short is not the issue.
Anyone have any ideas???
**Resolved!**
Ok, I got it running again. I replace the positive red battery cable from battery post to Main Fuse box and to starter (Same cable, two parts) and it fired right up.
Thanks to all replies, and thanks to Que89YJ for talking me through this on the phone!
UMDJesse is offline
post #2 of 12 Old 08-08-2011, 08:45 AM
Que89YJ
You must have a meter, you need to check the power at the PDC(Fuse block under the hood) check f5,6, and 8 with the meter and see if you have power. If yes then look at the second post about checking power at the ignition switch.
http://www.jeepforum.com/forum/f12/u...elays-1169030/
http://www.jeepforum.com/forum/f12/e...roblem-885427/
Que89YJ is offline
post #3 of 12 Old 08-12-2011, 07:47 PM Thread Starter
UMDJesse
Well my box doesnt exactly line up with the pic in the thread, but I have good power to f9, f6, and f3 which in my car is f9(fuel ecu) f6(ignition) f3(head lamp syst)
Any ideas?
UMDJesse is offline
post #4 of 12 Old 08-12-2011, 08:22 PM Thread Starter
UMDJesse
ok wait...so I just cleaned tightened checked everything and when I buttoned it all back up, put all the fuses back in. I went to try again...put the key in turned on the ignition and wham! I have power! Lights, I hear the fuel pump, everything. I go to turn the motor over then I hear a CLICK! and everything dies again. What gives????? fuseable link perhaps? What should I check???
UMDJesse is offline
post #5 of 12 Old 08-12-2011, 08:32 PM Thread Starter
UMDJesse
Ok, NEW UPDATE!!! I just disconnected the battery cable while I came up to write this on a hunch...whaddya know...power again, until I try to turn it over then pop! lights out again. So Im leaning strong towards some kind of short, but Im NOT blowing any fuses. Once it "Pops" out, I disconnect the battery cable for a few and everything works again. So something is resetting itsself every time I disconnect the batter cable, then blowing everytime I try to start. So Im thinking fuseable link.....Now Im aware of the concept, but have no idea where they are or what they look like????
UMDJesse is offline
post #6 of 12 Old 08-12-2011, 08:39 PM
Que89YJ
Not a short. Its an open. Use a set of jumper cables and jumper power from the battery to the pdc and battery negative to the chases. You have a bad power connection. Also check out you pdc wiring and the 40amp fuses.
Que89YJ is offline
post #7 of 12 Old 08-12-2011, 09:09 PM Thread Starter
UMDJesse
Ill give it a shot. But Im missing something.....the power wire from the battery to the pdc is 100% a-ok, the red wire itself is only about 10 inches long and in good shape. Am I thinking of the wrong cable? and none of the fuses are blown. Also I tested all of the grounds, but I guess by jumping the battery directly to the chassis I might bypass something Im missing? Also, I did take the pdc out and check all the wires underneath and everything looks pretty good. a little corrosion bu nothing serious.
and just to be sure..the 'PDC' is the main fuse block under the hood right?
UMDJesse is offline
post #8 of 12 Old 08-12-2011, 09:13 PM
Que89YJ
Yes. Sent you my number. Call me when you can
Que89YJ is offline
post #9 of 12 Old 08-13-2011, 08:23 AM
JWELK
I would suggest you have a bad ground. Check the neg bat terminal, clean both terminals to bright and shiny, then follow the black lead. Disconnect each point in the engine compartment 3 I think. Do one at a time and test and you will find the culprit, otherwise you won't know which one solved the problem.
Regards,
Jim W
JWELK is offline
post #10 of 12 Old 08-13-2011, 09:29 AM
MJMPC
Replace your + battery cable.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #11 of 12 Old 08-13-2011, 09:40 AM
redneck_vb
1987 YJ Wrangler
do you have a starter selonoid on that year?
"Is that you John Wayne?...Is this me?" - Full metal Jacket
redneck_vb is offline
post #12 of 12 Old 08-14-2011, 04:02 PM Thread Starter
UMDJesse
UMDJesse is offline
Dead Electrical Circuit Chad07 JK Wrangler Technical Forum 7 04-20-2011 08:37 AM
Jeep dead, battery dead, won't jump, need help ASAP 97jeepTJ TJ Wrangler Technical Forum 11 02-02-2011 04:35 PM
in-cab electrical ALL dead, gauges, lights and switches whatevah TJ Wrangler Technical Forum 5 08-04-2010 09:04 PM
Dead Jeep! Electrical/Fuse Issue?? malo8899 TJ Wrangler Technical Forum 3 05-23-2010 09:49 PM
Dead Jeep - electrical issue - Alt / regulator / battery? CTKen TJ Wrangler Technical Forum 5 09-26-2008 05:03 AM
