No Cutting Fender Flares - JeepForum.com
post #1 of 19 Old 04-17-2011, 05:29 PM Thread Starter
jhumphrey
Hey all,
Im getting ready to paint my Jeep now that the weather has warmed up. Im thinking about getting some fender flares before I do, because Im running 31x10.5's and they stick out to far and mud slings EVERYWHERE.
Anyway, does anyone know of some decently priced fender flares that will cover the tires but that I dont have to cut my jeep's rear wheel area to make fit? I saw xenon's kit, but Im not sure if you have to cut the back or not. Plus, I wouldnt mind finding some "cheaper plastic" since these will probably get dinged/dented/cracked on the trail.
Thanks
jhumphrey is offline
post #2 of 19 Old 04-17-2011, 06:49 PM
carlitos_90
if it says it for YJ im pretty sure it would not require any cutting of your tub... might need to drill new holes but thats about it.
i have the Xenon kit and they cover my 31s real well... almost to well makes my tires look tiny 0,0
DFW Area Monthly JeepMeet! Next one June 4th!
1995 YJ 2.5 LOW OUTPUT 31s 4.5" Lift
carlitos_90 is offline
post #3 of 19 Old 04-17-2011, 07:32 PM Thread Starter
jhumphrey
I have found a couple, I think its rugged ridge or someone that gives the YJ a sort of TJ flare. Could be Bushwacker, cant recall the brand. Anyway, the front mounts just like the standard flare. However, you have to cut the sheet metal of the rear fender, then measure and bolt the rear flare on. Im not crazy about the idea of cutting my Jeep, so Im seeking an alternative.
post #4 of 19 Old 04-17-2011, 07:50 PM
95yjkevin
I would also like to find out if there is a simple kit out there, I really don't want to cut fenders.
95yjkevin is offline
post #5 of 19 Old 04-17-2011, 09:48 PM
carlitos_90
@jhumprey i think your talking about placing just TJ flares (OMIX YJ fender falres kit requires this)... which would require cutting rear... just go with YJ Pocket flares regular
http://www.4wd.com/productdetails.as...=0&partID=4456
those would be ideal.. all it says requires drilling.. basically new holes ^^ so you can screw down the flares
comes with 6" coverage its 4 piece set...
post #6 of 19 Old 04-18-2011, 06:09 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
For a cheap alternative I went with "bushwacker" style flares I got from Ebay.
Do a search for "TAG fender flares". They are just under $200 and cover well. You do have to drill new holes but don't have to cut anything. I've had mine on for over a year now and they are holding up great. They seem a little stiff but do flex when rubbing against trees (I haven't rubbed any rocks with them... yet).
Like these:
http://roadreadydeals.com/jeep-yj-wrangler-bolton-fender-flares-19861995.html
HTH
-John-
johnboy68 is offline
post #7 of 19 Old 04-18-2011, 12:06 PM
CopperHead_Road
Originally Posted by jhumphrey View Post
Hey all,
Thanks
I have a set of TJ flares that i will sale you. They are a aftermarket 6" wide set that looks like the stock flares. They are a direct replacement for the stock ones and uses the same hardware and bolt holes.
I took them off of my Yj a few months ago. They are in good shape. I will let them go for $120 plus shipping. I live in East TN just NE of Knoxville. Let me know if you are interested.
Here is a pic of them on my rig....
"My Poppa ran whiskey in a big-block Dodge, he bought it at an auction at the Mason's lodge"
CopperHead_Road is offline
post #8 of 19 Old 04-18-2011, 12:20 PM
bread61
I have the rugged ridge extented flares got em off of e-bay I think 220.00 you could cut out of you want but I chose not to .. just painted the extra 2 inches on the rear black , you cant tell unless your on the ground looking up .. I just could not cut on her ... my sons on the other hand has been butcherd so much you have trouble knowing it was a Jeep
bread61 is offline
post #9 of 19 Old 04-18-2011, 12:29 PM
bread61
you can see the white showing on the front .. like I said just painted it flat black ..Just like the other fella I have some 6'' flairs that I had on it b4 the re-build but I liked these way better oh ya they are for sale as well Cheep
good luck
bread61 is offline
post #10 of 19 Old 04-18-2011, 06:11 PM
carlitos_90
@ CopperHead_Road..
those are YJ flares i got the same ones on my rig lol ..
btw its a YJ guys dont be afraid to cut so you can fit TJ flares,,, the bonus is the clearance..
today i cut my front fenders. to make them flat thinking of going tube ... if not then eh bonus clearance
post #11 of 19 Old 04-18-2011, 07:16 PM
Nibbley15
I am a Flat Style type of person and saw the same ones from Xenon, Bushwacker doesn't make them for a direct bolt on yet for the YJ (you can get the TJ but it's either cut or overhang).
And for over $400, not ready to drop the money yet myself, saving for that day.
http://www.central4wd.com/inventoryd...folder%7C75913
Nibbley15 is offline
post #12 of 19 Old 04-18-2011, 07:45 PM Thread Starter
jhumphrey
PM sent to you
"A woman's body is a work of art. A man's body is a utilitarian. It's for gettin' around. It's like a Jeep." - Elaine Benes
post #13 of 19 Old 04-18-2011, 10:19 PM
carlitos_90
@Nibbley ill prob b fender flareless for now hehe ... legal in TX
post #14 of 19 Old 04-19-2011, 08:05 AM
MudWrangler
Hey all,
Thanks
I have a set of TAG fender flare on my YJ. Running 35's they are 7" extensions,no cutting involved,and where cheap $200.00 off ebay.
Bry
MudWrangler is offline
post #15 of 19 Old 04-19-2011, 08:06 AM
CopperHead_Road
PM sent to you
Good deal, sent reply back at you...
CH_R
Rear Inner fender removal + Paint + trim fender flares Mike_Motorbike TJ Wrangler Technical Forum 17 08-31-2013 06:10 PM
Removing pocket-style fender flares replacing with factory flares domano 68 TJ Wrangler Technical Forum 18 04-09-2010 06:17 PM
Fender Flare Extensions for keeping grim off rear fender flares? FrankGG TJ Wrangler Technical Forum 7 12-05-2007 09:29 AM
Suggestions for cutting the rubber fender flares ? xaran YJ Wrangler Technical Forum 11 06-06-2007 03:04 PM
cutting fender flares cmoore TJ Wrangler Technical Forum 5 07-21-2003 11:49 AM
