NO Brakes in 4LOW - Page 2 - JeepForum.com
post #16 of 41 Old 05-12-2013, 05:53 PM
Reno72
If you're feeling good about no air in the lines, seems the next step would be master cylinder. Are you still running stock lines? I know you're turning some big meats, if you're running old lines might be good to change them, but unless their bulging, leaking or crimped they should not cause this.
Reno72 is offline
post #17 of 41 Old 05-12-2013, 08:13 PM Thread Starter
phil1330
1964 CJ5
I'm sure there is no air in the lines. I'm running stock hard lines but I'm running long stainless braided lines front and rear. No leaks no bulging. I haven't lost any fluid either.
I guess im gonna buy a master cylinder this week.
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #18 of 41 Old 05-13-2013, 10:12 AM
soonermatt
Here is my brutally honest assessment of this situation...
You had gears put in your jeep. The guy was probably lazy and didn't even unhook your calipers but instead just unhooked the brakes and figured he'd bleed them afterwards. Or he didn't even bleed them at all. Or he crimped a line or didn't get the connection between the rear brake line "right".
Either way your entire braking system has been compromised by something seemingly small but might be hard to diagnose.
You're on track to start something that you're probably not qualified to do (brake overhaul/master cylinder replacement) and you probably don't have the tools to do (have brake line flaring tool?).
My gut feeling is that you have air in your lines and need to go buy $15 (two quarts) of brake fluid and just cycle it through. If that doesn't solve your problem you need to mash on your brakes on some clean pavement for a couple minutes so you can find the leak. Act like Dr. House on this one...coincidences don't happen.
soonermatt is offline
post #19 of 41 Old 05-13-2013, 11:27 AM
SuperMidget
Sounds like the rear shoes need adjusting... in 4 low I don't care how good your front pads are they won't hold all 4 tires alone and the rear tires keep pushing unrestricted over powering the front brakes
The gear change just increased an existing problem you hadn't noticed... since I assume you went to lower gears now the extra leverage makes it really stand out
SuperMidget is offline
post #20 of 41 Old 05-13-2013, 01:47 PM
Rproject
1987 YJ Wrangler
I'd have to agree. I also agree with others who have indicated that you take it back to the guy who did your gears. If everything was working before you took it in and now it's not, it's their problem, not yours.
Personally, I wouldn't touch it. As soon as you touch it, you bought it!
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #21 of 41 Old 05-13-2013, 02:08 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
This. A reputable shop would take a look at the issue and fix it if it was cased by their mechanic. If it stopped fine before, they need to fix it.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #22 of 41 Old 05-13-2013, 02:33 PM
SuperMidget
What was the gear change from/to?
post #23 of 41 Old 05-13-2013, 04:50 PM Thread Starter
phil1330
1964 CJ5
4.56 to 5.38
phil1330 is offline
post #24 of 41 Old 05-13-2013, 04:56 PM Thread Starter
phil1330
1964 CJ5
that's the problem. i've dealt with these guys before and have never had a problem with them. I brought this to their attention before I pulled off the lot. They claim that they did nothing to the breaks nor disconnect any brake lines. I thought they were a reputable shop but when I left that day a sure felt SCREWED.
phil1330 is offline
post #25 of 41 Old 05-13-2013, 04:57 PM Thread Starter
phil1330
1964 CJ5
I'm going to give that a try. I've only messed with the front so far.
phil1330 is offline
post #26 of 41 Old 05-13-2013, 05:08 PM Thread Starter
phil1330
1964 CJ5
Ignorant assessment
phil1330 is offline
post #27 of 41 Old 05-13-2013, 05:24 PM
SuperMidget
I am only going with that suggestion because its the exact same issue I am fixing on my wife's 90 for a mud ride memorial weekend
New fronts but the rears don't hold at all right now
post #28 of 41 Old 05-13-2013, 07:08 PM
soonermatt
Ignorant assessment
I apologize. You said you knew the lines were bled because your lines werent bulging or leaking. This made me think you had no idea you knew what you're talking about because they aren't symptoms of air in brake lines -- your problems are.
I guess I stand corrected. Replace your already newer, oversized 95 master cylinder and let us know how it goes.
FWIW: your better master cylinder and booster will mask air in the lines better than your original 88.
Sorry for offending you with my ignorant statement.
Edit: I just considered how I feel when *******es comment on my build thread. Although sometimes they're right, I don't like hearing it. I really believe a fluid flush is worth trying. I need to be more respectful. Sorry.
post #29 of 41 Old 05-13-2013, 07:49 PM Thread Starter
phil1330
1964 CJ5
I apologize.
No worries.
This is what I'm going to do
phil1330 is offline
post #30 of 41 Old 05-31-2013, 05:54 PM Thread Starter
phil1330
1964 CJ5
Found the problem...Its a leaking master cylinder. I was told to use an E350 master cylinder. Is this a good fix? if so what year do I need to use?
phil1330 is offline
