NO Brakes in 4LOW - JeepForum.com
post #1 of 41 Old 05-11-2013, 06:24 PM Thread Starter
phil1330
1964 CJ5
NO Brakes in 4LOW
I dropped the jeep off at the shop to get gears installed front and rear the other day. The shop did the job but when i got in the jeep to test drive it the brakes were very weak.
I took the calipers off of the front and cleaned them with brake cleaner thinking the shop guys got there greasy *** hands all over the brake pads. And yes there was a little.
any ways the jeep stops ok on pavement in 2wd. It stops a little worse in 4 high, but it will not stop at all in 4 low. WTF!
Here's the set up. 88 wrangler w/95 booster and master cylinder. New brakes on all four corner.
What's the fix here guys?
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #2 of 41 Old 05-11-2013, 07:42 PM
Reno72
Is the pedal firm? Could it need bleeding. How about your booster, everything hooked up? In 4low it always seems the brakes aren't as strong, when you say it won't stop are you saying you feel no brake action or they just seem really weak?
Reno72 is offline
post #3 of 41 Old 05-11-2013, 09:15 PM Thread Starter
phil1330
1964 CJ5
Nah when i say it will not stop in 4 low i mean i would be out of complete control of jeep on a down hill trail. That brake pedal is down to the metal. And i did bleed the brakes first b4 i cleaned the pads and rotors.(forgot to post that)
And yea the pedal feels ok but not as firm as it should i think.
booster is hooked up properly and vacuum line is secure with no leaks
phil1330 is offline
post #4 of 41 Old 05-11-2013, 09:31 PM
OKwranglerYJ
Make sure your bleeders are on top
OKwranglerYJ is offline
post #5 of 41 Old 05-12-2013, 06:07 AM
Mark05059
If you took it to a shop... stop working on it and take it back to THEM so they can fix it. They messed it up.. they should make it right.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 41 Old 05-12-2013, 08:11 AM
Dirttracker18
I see no reason for the shop to touch anything to do with the brakes when changing gears.
I would have to think the two are unrelated.
In addition there is no relationship between your brakes and your transfer case.
Switching to 4low cannot affect your brakes. It may amplify an existing problem though.
Dirttracker18 is offline
post #7 of 41 Old 05-12-2013, 08:28 AM
Xpress
Air in the lines still. Or the master cylinder is bad.
All about that unibody life.
Xpress is offline
post #8 of 41 Old 05-12-2013, 10:57 AM Thread Starter
phil1330
1964 CJ5
yea the guys at the shop said they did nothing to brake system.
phil1330 is offline
post #9 of 41 Old 05-12-2013, 10:59 AM Thread Starter
phil1330
1964 CJ5
that was one of my thoughts. either the master cylinder or the booster. but i just didn't want to start throwing parts at it.
phil1330 is offline
post #10 of 41 Old 05-12-2013, 01:04 PM
4.7stroker
They had to pull the axles to change the gears. To do that they had to remove the brakes.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #11 of 41 Old 05-12-2013, 02:19 PM
Dirttracker18
Dwayne
True I guess "not touch" is overstated. They shouldn't do anything to the system. Pull the calipers, pull the rotors, do the change and put back together. You shouldn't even need to press the caliper, just slip them back on.
However you got me thinking. If the tech was less then professional, he may have left the rotors dangling from the hoses. That could cause some issues.
post #12 of 41 Old 05-12-2013, 03:05 PM Thread Starter
phil1330
1964 CJ5
calipers dangling could cause what kind of issues?
phil1330 is offline
post #13 of 41 Old 05-12-2013, 03:45 PM
Dirttracker18
Stretching of the hose which could cause a leak or damage the hose allowing expansion causing a soft peddle.
You should never let the calipers hang by the hose.
post #14 of 41 Old 05-12-2013, 04:15 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I've seen axles flexed so that the brake lines were so tight you could play a tune on them and were not leaking. As much as I would advise against dangling calipers, its not gonna kill anything.
Luck Favours The Prepared
Anticanman is offline
post #15 of 41 Old 05-12-2013, 05:14 PM
OKwranglerYJ
If they took the calipers off and tossed them in a pile then they could have switched them and if they did you wouldn't be able to bleed them properly.
