-   -   NO Brakes in 4LOW (http://www.jeepforum.com/forum/f12/no-brakes-4low-1522092/)
phil1330 05-11-2013 06:24 PM
NO Brakes in 4LOW
I dropped the jeep off at the shop to get gears installed front and rear the other day. The shop did the job but when i got in the jeep to test drive it the brakes were very weak.
I took the calipers off of the front and cleaned them with brake cleaner thinking the shop guys got there greasy *** hands all over the brake pads. And yes there was a little.
any ways the jeep stops ok on pavement in 2wd. It stops a little worse in 4 high, but it will not stop at all in 4 low. WTF!
Here's the set up. 88 wrangler w/95 booster and master cylinder. New brakes on all four corner.
What's the fix here guys?
Reno72 05-11-2013 07:42 PM
Is the pedal firm? Could it need bleeding. How about your booster, everything hooked up? In 4low it always seems the brakes aren't as strong, when you say it won't stop are you saying you feel no brake action or they just seem really weak?
phil1330 05-11-2013 09:15 PM
Nah when i say it will not stop in 4 low i mean i would be out of complete control of jeep on a down hill trail. That brake pedal is down to the metal. And i did bleed the brakes first b4 i cleaned the pads and rotors.(forgot to post that)
And yea the pedal feels ok but not as firm as it should i think.
booster is hooked up properly and vacuum line is secure with no leaks
OKwranglerYJ 05-11-2013 09:31 PM
Make sure your bleeders are on top
Mark05059 05-12-2013 06:07 AM
If you took it to a shop... stop working on it and take it back to THEM so they can fix it. They messed it up.. they should make it right.
Dirttracker18 05-12-2013 08:11 AM
I see no reason for the shop to touch anything to do with the brakes when changing gears.
I would have to think the two are unrelated.
In addition there is no relationship between your brakes and your transfer case.
Switching to 4low cannot affect your brakes. It may amplify an existing problem though.
Xpress 05-12-2013 08:28 AM
Air in the lines still. Or the master cylinder is bad.
phil1330 05-12-2013 10:57 AM
yea the guys at the shop said they did nothing to brake system.
phil1330 05-12-2013 10:59 AM
that was one of my thoughts. either the master cylinder or the booster. but i just didn't want to start throwing parts at it.
4.7stroker 05-12-2013 01:04 PM
They had to pull the axles to change the gears. To do that they had to remove the brakes.
Dwayne
Dirttracker18 05-12-2013 02:19 PM
Dwayne
True I guess "not touch" is overstated. They shouldn't do anything to the system. Pull the calipers, pull the rotors, do the change and put back together. You shouldn't even need to press the caliper, just slip them back on.
However you got me thinking. If the tech was less then professional, he may have left the rotors dangling from the hoses. That could cause some issues.
phil1330 05-12-2013 03:05 PM
calipers dangling could cause what kind of issues?
Dirttracker18 05-12-2013 03:45 PM
Stretching of the hose which could cause a leak or damage the hose allowing expansion causing a soft peddle.
You should never let the calipers hang by the hose.
Anticanman 05-12-2013 04:15 PM
I've seen axles flexed so that the brake lines were so tight you could play a tune on them and were not leaking. As much as I would advise against dangling calipers, its not gonna kill anything.
OKwranglerYJ 05-12-2013 05:14 PM
If they took the calipers off and tossed them in a pile then they could have switched them and if they did you wouldn't be able to bleed them properly.
The time now is 08:53 PM.
