No Brake and signal light - JeepForum.com
post #1 of 3 Old 07-24-2001, 01:41 AM Thread Starter
ayadov
I need help!!!!
I have 1992 jeep wrangler
just start last week, I lost the brake light and the signal also, the fuse was blown out
every time that I change to a new fuse it blown right away what I hit the brake or turn the signal, I checked the light bulb they all ok, I even replace the brake switch got no luck, I know that I have a short some
where, if there is someone that went thru this before I would like to here what can be the problem, please point me to the right place. any help will do
ayadov is offline
post #2 of 3 Old 05-26-2002, 10:47 AM
jfarrell
Anyone ever come across this problem? Mine just started this Fri and I can't figure it out. Did the same things as above and am not sure where to go from here.
jfarrell is offline
post #3 of 3 Old 05-26-2002, 10:58 AM Thread Starter
ayadov
well i did fix it, what i found was that the wire
that go in the back between the 2 lights, right under the back door and above the fuel tank was
shorting on the body, I fix that and the fuse never blown again so far, let me know if you need help or some photo on the location
arik
ayadov is offline
brake/signal light wiring problems JIBTEXHNKA YJ Wrangler Technical Forum 3 11-25-2009 08:59 PM
RT Turn Signal/Brake light tjtone TJ Wrangler Technical Forum 2 03-30-2007 01:27 PM
Turn Signal and Brake Light Jeep_Grrl TJ Wrangler Technical Forum 8 08-13-2005 04:24 PM
Brake light/signal issues ClarkAM1 TJ Wrangler Technical Forum 3 04-11-2005 12:18 PM
signal light goes on when I brake Decz TJ Wrangler Technical Forum 9 02-24-2005 07:20 AM
