No 4 low, 4 high works, can the central axle disconnect be to blame? - JeepForum.com
post #1 of 3 Old 08-09-2010, 03:22 PM Thread Starter
geocraig77
Pardon my redimentary understanding of the 4WD system, but I have been addressing other issues in the hopes of taking a fully functional YJ for some real off-road action. My problem is getting into 4 lo. At park it seems to slip in, but when in gear it grinds terribly until I pop it out. 4 hi works. My neighbor said it may be the CAD fork not engaging and suggested the OX lockign cable for the CAD. Is that right? If the fork was the issue wouldn't 4 hi not work too?
BTW, after reading this forum I went with a MC2100 and the TFI upgrade and couldn't be happier. I just got it dialed in and MAN what a difference from the old edelbrock that was on there. If I can get the 4 lo figured out and do something with my sagging RC front springs, I'll be in business.
geocraig77 is offline
post #2 of 3 Old 08-09-2010, 03:25 PM
Larry93
No it would not be your CAD system, as you thought.
I would look at your Z gate shift & linkage as possible suspects.
Larry93 is offline
post #3 of 3 Old 08-09-2010, 03:37 PM
dadstoy
Sounds like the linkage needs adjusting to me.
dadstoy is offline
I keep getting axle wrap should i blame shackles?? crazyquadder YJ Wrangler Technical Forum 14 04-20-2010 01:19 PM
A good pic of the Central Axle disconnect. Jeepsr4me19 YJ Wrangler Technical Forum 1 11-10-2009 12:56 PM
Inspection station said I'm lifted too high. Need one in central Mass. UltimatE Wrangler General Discussion 33 10-24-2009 06:49 AM
Central Axle Disconnect gasket? ZeroGravity YJ Wrangler Technical Forum 2 02-23-2009 04:23 PM
Fan only works on high 35sUnlimited TJ Wrangler Technical Forum 3 12-06-2006 09:16 PM
