Nitro chromoly 4340 axle shafts - JeepForum.com
post #1 of 3 Old 04-01-2010, 08:15 AM Thread Starter
tx_medic
Has anyone put these in their Dana 30 yet? How'd they go in, simple? Will they fit with an aftermarket Axel tube seal you see all over the place? Supior makes a pair for about $80.
-LS
'92 YJ
'13 JK
'95 ZJ
tx_medic is offline
post #2 of 3 Old 04-04-2011, 08:31 PM
digizure
I'm curious to hear some reviews on the Nitro Chromoly Shafts...Anyone?
digizure is offline
post #3 of 3 Old 02-07-2012, 03:48 PM
NITBRubicon
I've been running them for a year with zero issues. So far so good. Front with spicer 5-760x u-joints, timken bearings, full cirlce clips, 35's and locked. Rear with timken bearings 35's and locked. Dana 44's.
My only complaint is I had to grind down the rear grade 8 bolts (wheel lugs) to clear my parking brake. Took the head half way down and so far they're good.
NITBRubicon is offline
Alloy USA Dana 30 and Ford 8.8 Chromoly axle shafts install write up barry1me TJ Wrangler Technical Forum 14 06-29-2010 08:32 AM
Chromoly axle shafts labor ? b0bbymc TJ Wrangler Technical Forum 6 09-14-2009 03:23 PM
Opinions on Nitro axle shafts? johnjk TJ Wrangler Technical Forum 0 09-14-2009 12:31 AM
Alloy USA D30 Chromoly Front Axle Shafts ryne0149 TJ Wrangler Technical Forum 22 01-19-2008 10:24 AM
4340 chromoly axles? okeefe11 TJ Wrangler Technical Forum 2 03-06-2007 09:19 AM
