Nissan Pathfinder tire carrier - JeepForum.com
post #1 of 10 Old 05-25-2013, 12:28 PM Thread Starter
jbolty
jbolty's Avatar
There have been a couple requests for a write up, but I never did one. A picture is worth 1000 words. I took advantage of the offset of the carrier and added a little more to the bumper which allows the jerry cans to sit inside between the tire and tailgate.
jbolty is offline
post #2 of 10 Old 05-25-2013, 12:44 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
That'll work, Jeff.
Do you use straps to secure the cans?
Joe Dillard is offline
post #3 of 10 Old 05-25-2013, 01:00 PM Thread Starter
jbolty
jbolty's Avatar
That'll work, Jeff.
Ratchet strap cut off short. I had a black bungee for a while but the sun ate it.
jbolty is offline
post #4 of 10 Old 07-11-2015, 10:26 PM
ZR90YJ
Hey jbolty, what are the measurements of the metal you used for it? I want to make mine like this. Looks good.
ZR90YJ is offline
post #5 of 10 Old 07-12-2015, 01:08 PM Thread Starter
jbolty
jbolty's Avatar
the main bumper is 2x4x 1/4
the rest is just scraps
jbolty is offline
post #6 of 10 Old 07-12-2015, 04:30 PM
ZR90YJ
Originally Posted by jbolty
the main bumper is 2x4x 1/4 the rest is just scraps
okay thanks man. I shall embark on my journey of pathfinder tire carrier
ZR90YJ is offline
post #7 of 10 Old 07-12-2015, 05:52 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
I have to question the pole. I can tell from the images that it is thick walled tube, but I can also clearly see that its flexing with the weight of the tire in two different pics.
Had you considered using the tub mounting with pinch plates like the original Nissan design employed? I know you wanted to mount jerry cans behind it, but that may have still been achievable by extending the brackets out a bit from the tub. Usually I try not to criticize other peoples fab work because I don't do my own fab work, but the only weak point I see is that tube. Maybe use a cap that mounts to the top of the pole and secures it to the tub and eliminate the bend? I dunno.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #8 of 10 Old 07-12-2015, 06:24 PM Thread Starter
jbolty
jbolty's Avatar
the latch lines up and snaps shut every time without any lifting. If there is any sag it's not noticeable.
that tube is at least 3/8 wall, maybe thicker
jbolty is offline
post #9 of 10 Old 07-12-2015, 06:25 PM
Luuca
Luuca's Avatar
Must be the pictures then.
YJOTM never
Luuca is offline
post #10 of 10 Old 07-12-2015, 07:46 PM Thread Starter
jbolty
jbolty's Avatar
probably. I guess it does look a little deflected in the pix.
not every mod is for everyone but this has served me well for several years of beating the snot out of my jeep.
this time of year is off season for us. Getting ready to do a cage and hydro steer,
jbolty is offline
