-   -   Nice Suspension Setup Help (http://www.jeepforum.com/forum/f12/nice-suspension-setup-help-1329714/)
SKYOFSCORPIONS 02-16-2012 02:41 AM
So I have a '92 Jeep YJ with a 4" Lift that's probably 10 or more years old. It has 33" tires and it has a slip yoke eliminator. I bought this Jeep a little over a year ago and the guy I bought it from said the slip yoke eliminator was recently added. The shocks on this thing are dead, it might as well not have any at all :laugh:. So it's time to fork out some money and redo all of the suspension. I'm talking bushings, lift kit, control arms. Another thing, everything under the Jeep is covered in a nasty grim, so once I remove the old suspension, I hope to take time to clean the underside as best as I can.
Now onto what I am wanting to do/accomplish and I hope you guys can point me in the right direction. In a year or so, I plan on upgrading wheels and tires to 35" so I think the new lift kit should be higher than 4". I've been told a lot to go with Rubicon Express and their stuff seems really nice. They have a 4.5" Extreme Duty Kit which is really nice http://www.jeep4x4center.com/jeep-li...ong-arm-yj.htm and they have a Spring-Over Conversion type lift kit http://www.jeep4x4center.com/5-5-spr...ub-re5015.html. Which of these would be a better choice? What other kind of bushings and control arms would I need to replace everything?
timatoe 02-16-2012 05:15 AM
No control arms on a YJ. There's a lot more to going SOA than what's in that "kit" and most of us here will tell you not to use a kit anyhow. If you're going to get the RE springs definitely go with the extreme duty kit, I'd also recommend you look into BDS or OME for springs as well. I went with the BDS springs and would do so again without hesitation. I have no experience with OME but wouldn't hesitate to use them in the future based on the praise they receive here.
Mean Max 02-16-2012 06:56 AM
BDS in the SUA height of your choice for the win.
/end thread
Max
4x4JB 02-16-2012 07:01 AM
I have been looking for the same thing. Eventually want 35's. OME I think only goes to 2.5" lift(??) The RE and BDS are the way to go. I saw on RE website that with the 4.5" you can tuck 35's with slight modding(trim fenders or additional 1" shackle/body lift). The SOA is more work from what I have seen. Good luck
SKYOFSCORPIONS 02-16-2012 12:02 PM
I just looked at the BDS stuff and saw they have a 6" lift which I bet would work. http://bds-suspension.com/product?ma...4&yr=1987-1995
The SOA may be overkill for what I am wanting. Do you think the BDS has everything I will need?
timatoe 02-16-2012 04:56 PM
Yes
They are also a vendor here on JF, check out the vendor thread toward the top of the forum.
dillonjm 02-16-2012 05:52 PM
Just to address some additional things you didn't mention.
First, 6" is more than enough for 35's. You could get by with less and avoid some of the issues associated with taller springs. I'd consider a set of their 3.5" springs and a small shackle lift (.5"-1") in conjunciton with a 1" BL or go for a set of their 5" springs sans the rest. Either is a decent method of achieving the same thing.
Adding TJ flares can also open up the wheel wells a little (requires a little body trimming, nothing serious). Either way you go, BDS, OME or RE springs are all good choices.
Secondly, for 35's you're going to need to start addressing drivetrain strength issues as well, specifically the rear axle and maybe an upgrade to the front axle shafts if you do any wheeling. Lots of info on ways to do both of these on the forum.
Good luck with your build. You're well down the right track with the springs you're considering.
SKYOFSCORPIONS 02-17-2012 12:53 AM
Good, because I plan to upgrade to dana 44's with a locker before I even do the 35" tires.
What issues are associated with taller springs btw?
metalry101 02-17-2012 01:24 AM
I'd go with either the BDS 5" or RE 4.5" Extreme Duty. My brother has the RE 2.5" Extreme Duty (now discontinued) and he loves it. He's had it for probably 6 or 7 years now, maybe even more actually, and it's still working well. Like others have said, OME is quality, but they don't make anything even close to tall enough to clear 35's. The reason I'd go w/ the BDS 5" over the 6" is that I believe they come w/ the same springs, and if you need more height, you can always add the taller shackles later.
SOA is definitely in play at that height and tire size, and if you're a skilled welder/fab artist or have some friends who are, not to mention some coin to drop on steering and other issues related to SOA, it's certainly worth considering. It won't just be a bolt on swap, but if you're going w/ Dana 44's anyway, you'll already be doing a fair amount of custom work w/ spring perches, brake lines, steering, etc, so going SOA isn't necessarily much more work. One additional part (out of many probably) that you'll need to buy or make for an SOA conversion is a traction bar for the rear to control axle wrap. I've read that it's a must on an SOA YJ.
Mean Max 02-17-2012 06:02 AM
I know this is a popular idea, but it seems like a lot of work for not a lot of payoff to me.
In my opinion, the Dana 44 isn't significantly stronger than the Dana 30 for the front, but it's a lot of work.
Rear axle swaps are easier, and a Ford 8.8 is much stronger than a Dana 44 & is easier/cheaper to find.
A well done Dana 30 & Ford 8.8 combination is a pretty good arrangement, in my opinion.
Max
95 Lowbuck 02-17-2012 07:18 AM
4" is about the most you should go with a stock length spring.
Anything more and the spring's arc will limit the travel.
As said a B.L. and or a shackle lift will help with fitting 35" tires.
SOA is a lot of work but if done right produces great results.
Anticanman 02-17-2012 09:14 AM
I disagree with this. I installed 1" shackles and the extra length gives the spring enough room to flatten out. Notice how the drivers side spring up front is completely flat? And yes, I was retesting for bumpstops.
http://i899.photobucket.com/albums/a...n/faefb62c.jpg
SKYOFSCORPIONS 02-17-2012 02:20 PM
Would the Dana 30 able to handle 35" tires?
The SOA sounds like a great setup, but probably more than I really need. So I guess it's between the RE 4.5" and the BDS 5". RE recommends a 1" body lift to use 35" tires. Is a body lift or longer shackles better?
Anticanman 02-17-2012 03:40 PM
You can run the Dana 30 with 35" tires. I run mine on 36" tires but I have built mine up a little bit. For the springs, I would suggest a BDS 5" with a shackle lift as the RE kit has a shackle lift included. Buy the springs separate and piece it together to save some monies. Longer shackles will help flex out the arch in the spring
giggityjeeper 02-17-2012 03:51 PM
ome 36R are over 3" lift. add shackles and your good, if you doin SOA that is all you need...
http://i157.photobucket.com/albums/t...ldy2011016.jpg
http://i157.photobucket.com/albums/t...p/IMAG0614.jpg
http://i157.photobucket.com/albums/t...p/IMAG1235.jpg
SOA with OME 36R springs, OME greasable shackles, no BL, 33 TSLs rockey road OTT highsteer.... its tall for sure but not bad.... NO tracs NO sway
The time now is 11:01 PM.
