Newer Computer PCM pin-out diagram HERE! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Newer Computer PCM pin-out diagram HERE!
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 10-06-2010, 09:46 AM   #1
five-string
I had a hard time tracking down this info. Since I was finally able to find it, I an sharing here so other searches will be able to access it.
This is the pin-out for the PCM, ECM, computer, brain, or whatever you like to call it for a 2000 Jeep XJ. I believe this applies to '96-'06 vehicles. If I'm wrong, please post corrections.
Yeah, I know this is the YJ forum, but there are many folks using the cherokees as donors these days. And I'm betting the '96 and up YJ is very close to this schematic.
This is the unit with three plugs going into it like this:
Here are the three plug's pin-outs:
Number 1:
Number 2:
Number 3:
UPDATE: Pin 17 on the gray connector contains a black/pink wire. This is the Check engine light wire to be used in the dash for retrieving codes. Use this wire as a ground (I used a LED)
Boycott shampoo! Demand the REAL poo!
White Jeep Club #119
☼lllllll☼
five-string is offline   Reply With Quote
Unread 10-21-2011, 10:23 AM   #2
sikpupy
I needed a 1997 XJ pinout but, hey, every bit helps on the web, thanks.
sikpupy is offline   Reply With Quote
Unread 10-21-2011, 11:11 AM   #3
jsawduste
Trying to convert from OBD2 96 up to OBD1 95 and down is going to be a nightmare for the average person.
Good information but it will be FAR easier to stick with OBD1 or OBD2 matched parts/configurations. Not saying it cannot be done but why expend all the extra effort.?
jsawduste is offline   Reply With Quote
Unread 10-21-2011, 11:34 AM   #4
Que89YJ
It's been done here on a few of the YJ's. Thanks for the info. Did you just do it to yours?
Que89YJ is offline   Reply With Quote
Unread 10-21-2011, 12:44 PM   #5
jsawduste
Did they convert to OBD2 or just use the harness and adapt it to OBD1 ?
Asking as I have considered changing to OBD2 to get more flexibility in programming the engine cals for the stroker.
Don`t know of any software that interfaces with OBD1 but there are several that will interface with OBD2.
Unread 10-21-2011, 01:07 PM   #6
Que89YJ
You have to do the under hood stuff and depending on what year you have some mods to the IP. It's a little more difficult but not too bad. There is no way to flash the OBD1 controllers so you are right, if you stroke it you want the OBDII. The engine block is the same so it's wiring mod and swap. If you ever decide to do it I would gladly come over and lend a hand. You aren't too far from the tech center. I use to sail out of North Star on the Clinton River.
Unread 10-21-2011, 01:23 PM   #7
jsawduste
I just might do that. You recall I completely rewired the YJ from end to end so the engine harness doesn't bother me. The IP is aftermarket so that to would be easy to change over also.
The stroker is running pretty well but I`d still like to trim the curves a bit.
Did`nt know you were a salior. Remember George Laplante ?
Might just take you up on the offer.
Unread 10-21-2011, 01:58 PM   #8
Que89YJ
Wow, if you knew George then you knew NorthStar! I crewed on a Thomas 35 until I got hurt in a car crash. I havent been the same since. The Owner of the the boat I crewed on was Dennis Meagher. He was the county planner for Macomb. His son sails the boat now. Great guy, great family, great crew, and many many good times.
I remember the talks we had when you were wiring it. You probably have the best wired YJ out there! Let me know. It would be fun to do.
Unread 10-21-2011, 02:30 PM   #9
jsawduste
I`ll call you. Still have your phone #
computer , diagram , ecm , pcm , pin
