Newbie with a question - JeepForum.com
post #1 of 12 Old 04-17-2010, 08:37 PM Thread Starter
Dano98
I am new to the forum and jeep world. I just got a 1992 Jeep Wrangler YJ 2.5L. When i was driving home after picking it up all the guages worked good. The drive is about 45 min. About 15 minutes from my house the temperature started to rise i turned on the heat in the jeep and it keep going back in forth. By time I got home and parked the jeep the needle was right above 260. The jeep didn't overheat.
I have searched the forum and read over a couple of items to replace. I have replaced the thermostat and the temp sensor. when I start it up and it starts to get warm the temp guage automatically goes to about 250. I am not sure what to check next.
Thanks,
Dan
Dano98 is offline
post #2 of 12 Old 04-17-2010, 08:51 PM
little_Jeep
Check the level and condition of your fluids.... any coolant loss? You said that temp gauge read high, but Jeep didn't over heat... I ssume you mean it didn't boil over? Did you feel hood to get an idea of how hot this Jeep got? Any other issues?
little_Jeep is offline
post #3 of 12 Old 04-17-2010, 09:50 PM
Stryker777
Stryker777's Avatar
Did you verify your fan is working correctly?
92 XJ, 4.0 NP231 - Stock to rebuild for my daughter, 235x75R15s
95 YJ, 2.5 NP231- 1" shackle, 4.0 tb, 19lbs injectors, e-fan, 31x10.5R15 Treadwright tires.
93 ZJ, 4.0 w/AW4 NP231 - 2" BB, 1 inch spring lift, 31x10.5R15 Cooper AT3 tires.
In GOD we trust. It's a Jesus thing.
Stryker777 is offline
post #4 of 12 Old 04-17-2010, 10:24 PM
87YJBill
1987 YJ Wrangler
make sure the radiator is not plugged, use an infared thermometer and check, also jeep has never been known for good consistent working gages.
87YJBill is offline
post #5 of 12 Old 04-18-2010, 03:34 AM Thread Starter
Dano98
I have checked all the other fluids and everything is good. Correct it didn't boil over. I didn't feel the hood to see how hot it got. There are no othere issues.
The fan is working correctly. I stated before that it all was working fun for about 30 while i was driving then the guage started to read high.
The radiator is not clogged. It is a new radiator. I will get a infared thermometer and check the radiator.
Dano98 is offline
post #6 of 12 Old 04-18-2010, 06:06 AM
little_Jeep
The first thing you need to determine is do you have an overheating issue, or just a faulty guage. Infrared will tell you this pretty quickly. I'm not a 2.5L guy, but when the radiator cap is removed (cold engine), can you see directly into the radiator to see the coolant? If yes, leave cap off, start engine and allow it to run until your thermostat opens...... watch for good coolant flow, you should be able to see movement in the coolant. If not, you may have a bad thermostat or the fins on the rear of the water pump maybe worn off. You stated that you just purchased this Jeep... then you stated it has a new radiator, this makes me wonder if prior owner wasn't having this issue and just never found the cause, or didn't like the cause he found.
post #7 of 12 Old 04-19-2010, 02:27 AM Thread Starter
Dano98
I changes the thermostat and temp sensor. I started the jeep and within 5 minutes the temp guage was already reading 260. I let it idle for about 20 minutes then i took it for a 10 minute drive didn't not boil over and no steam like it was over heating. I have come to the conclusion that the guage is broken.
Dano98 is offline
post #8 of 12 Old 04-19-2010, 03:23 AM
Mark05059
how did you come to this conclusion with out finding out the actual temperature of the cooling system?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #9 of 12 Old 04-19-2010, 05:02 AM
asbury
there is a temp sensor and a temp switch on the 2.5s temp switch controls the gauge and is located on the cyl head drivers side back be side valve cover temp sensor is on thermostat housing
JEEP NAKED !!
asbury is offline
post #10 of 12 Old 04-19-2010, 05:04 AM
MJMPC
Where was the temp sensor you changed?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #11 of 12 Old 04-19-2010, 09:36 AM
kennemore_m
If you really think your temp gauge is not working, try attaching an after market one. You can buy them Harbor Freight for about $10 and they are very easy to install. That would let you know for sure if it is a gauge problem.
kennemore_m is offline
post #12 of 12 Old 04-23-2010, 07:16 AM
CrawlingForward
How fast do changes in the needle happen? Does it gradually and evenly move up over the 5 minutes, or does it seem to all of a sudden accelerate?
Also, does it keep normal behavior when you turn the car off?
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
newbie here with a question wvcracker YJ Wrangler Technical Forum 24 02-24-2010 10:23 PM
Newbie Jeep owner w/ a newbie Jeep question bigjim72 YJ Wrangler Technical Forum 12 08-21-2009 08:46 AM
Newbie Question YJMan327 YJ Wrangler Technical Forum 6 04-11-2008 09:01 AM
RE3.5 or 4.5 newbie question Rayvins TJ Wrangler Technical Forum 10 10-05-2007 09:18 PM
Newbie Question? Shawno TJ Wrangler Technical Forum 10 09-17-2002 07:43 AM
