newbie needs serious help - JeepForum.com
 9Likes
post #1 of 31 Old 09-21-2017, 06:33 PM Thread Starter
Cincinnatiredyj
I have a stock 95 yj minimal rust which was one of the factors i was looking at when I got my Jeep.
On my way home I had a backfire & thought to check out the cause when I got home, while letting the dog out I noticed flames coming out the rear passenger tire well. A call to the fire dept to got it extinguished. Here's where I need the help where do I start so I can get my Jeep back on the road. I know i will need a tire and some wire harness that is back there by the bumper.
Cincinnatiredyj is offline
post #2 of 31 Old 09-21-2017, 07:41 PM
shaggyjim
shaggyjim's Avatar
Welcome to JeepForum and sorry to hear your rig went up like a Pinto. First thing is find out what the heck caused the fire in the first place and fix that. My guess would be with the exhaust but I could be wrong. Next thing I would check is the poly fuel tank. That close to a fire should have melted a good bit of it.
cyoos and sptrmike like this.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #3 of 31 Old 09-21-2017, 08:02 PM
cyoos
^^^ This, and welcome to the forum.
4.6L/AX15/OME/1" booms in back/8.8-4.10-LSD/XJ D30 in work/32" Falken Wildpeak AT's
cyoos is offline
post #4 of 31 Old 09-21-2017, 09:48 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
If a call to the fire department got it extinguished how are we even discussing what to fix? What's left of the Jeep? Pics? We can't just guess here...
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #5 of 31 Old 09-22-2017, 03:09 AM
Jeepsr4me
The exhaust dont normally get that hot back near the tank.. Dropping the tank would be the 1st thing I look at. Then any wires around the area, You need fuel, heat and combustion to start the fire..
DirtKar likes this.
Jeepsr4me is offline
post #6 of 31 Old 09-22-2017, 04:45 AM Thread Starter
Cincinnatiredyj
Pics of the damage
IMG_1450_1506077006383.jpg   IMG_1452_1506077026768.jpg   IMG_1453_1506077050591.jpg
post #7 of 31 Old 09-22-2017, 05:25 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
That's one fast fire department!
I don't know how that thing didn't go up in a ball of fire that close to the gas tank.
It looks like it started in you muffler. Probably had a buildup of junk then the backfire gave it some raw gas and a flame.
I'd say your gonna need some body work and a new exhaust at the very least. Then some new wiring for the tail light.
I've got a stock rear flare you can have.
Looking forward to watching this one get back on it's feet.
-John-
johnboy68 is offline
post #8 of 31 Old 09-22-2017, 05:47 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I hope it was insured for comprehensive. All of my vehicles always are. If so, that cash should help with the wallet aspect anyway.
DirtKar likes this.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #9 of 31 Old 09-22-2017, 05:57 AM Thread Starter
Cincinnatiredyj
I'm taking the day off. Planning to drop the gas tank to see if I can find the cause and start a list of items I need to get it back on the road.
post #10 of 31 Old 09-22-2017, 11:58 AM
mike134
My guess is that either leaking fuel caused this, or oil slung out from the transfer onto the exhaust. You will almost certainly need a new gas tank. If there is any sign of heat damage, don't risk the possibility of a weakened polymer tank. Change the hoses while the tank is dropped.
And the last possibility, the catalytic converter burned up.
One of the big san diego forest fires was caused by the catalytic converter honeycomb clogging, reaching super high temperature, then shooting out the back of the exhaust pipe and into the brush on the side of the road...
Sand about 6 inches in every direction around any black spot down to bear metal and then prime it. You can worry about painting later.
mike134 is offline
post #11 of 31 Old 09-23-2017, 10:40 AM
cyoos
Originally Posted by Cincinnatiredyj View Post
The melted flare is obviously an omen. Do a search for 'YJ highline mod' and grab your sawzall.
bruinjeeper likes this.
cyoos is offline
post #12 of 31 Old 09-23-2017, 10:54 AM
mike134
Its ok... After the fire your name is now:
Cinncinna Tired YJ.
mike134 is offline
post #13 of 31 Old 09-24-2017, 03:53 PM Thread Starter
Cincinnatiredyj
The exhaust has been taken off fro in front of the muffler back, there was no catalytic converter and the gas tank has been dropped.
How did it not blow up all together ?
How do I choose which poly tank & sending unit ?
bruinjeeper and cKruzer like this.
post #14 of 31 Old 09-24-2017, 05:00 PM
shaggyjim
shaggyjim's Avatar
That's incredible!
Tophog1 likes this.
Jim...
post #15 of 31 Old 09-24-2017, 05:40 PM
JeeperDon
JeeperDon's Avatar
That'll all buff out. I'd wheel it!
Luuca likes this.
Web Admin for
