newbie needs help 89 wrangler 4.2 misfires - Page 2 - JeepForum.com
post #16 of 25 Old 11-02-2011, 04:30 PM Thread Starter
Snicklfritz
now ready for the rebuild
Snicklfritz is offline
post #17 of 25 Old 11-03-2011, 02:20 PM Thread Starter
Snicklfritz
getting ready to put back on hope she starts right up
post #18 of 25 Old 11-03-2011, 08:53 PM Thread Starter
Snicklfritz
fired right up no problems at all
post #19 of 25 Old 11-04-2011, 05:20 AM
Duvalbulldog
Isn't that the best best thing in the world after all you went through with the frustration and aggravation and when you hear it fire up that since of relief. But as we all know the YJ's purpose in life is to make sure that we are never bored and continues to give us new challenges lol. As soon as we fix on thing one or more surface. I love my YJ.
Duvalbulldog is offline
post #20 of 25 Old 11-04-2011, 09:34 AM Thread Starter
Snicklfritz
ya i love when you fix something and it works perfect, but it was short lived. while i was dialing in the choke the idle started bouncing up and down, pulled air cleaner and was watching stepper motor, it was moving in and out. so i think it was trying to recover when i dropped the idle from fast idle maybe o2 sensor is starting to go bad what do you think.
post #21 of 25 Old 11-04-2011, 10:25 AM
superj
i think its that carb, ha ha ha. i am glad mine was swapped out before i got this jeep. i have not read a good thing about those carbs
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #22 of 25 Old 11-04-2011, 10:54 AM
1SASjeepster
That looks like a carburetor spacer. It is designed to give you more horsepower through higher velocity air flow. This would not cause a miss even if it was leaking. You seal this spacer with gaskets, top and bottom. The miss is caused by your spark plugs being corroded. I say this, because you said you checked all of your wires and did what "dancytron" said. (The easiest way is to let the motor get up to temperature... meaning, hot water is felt through your upper radiator line because the thermostat just opened up. Then turn the engine off and pull one plug wire. Now start up the engine and see. Let it run for a little while. If it is the cylinder causing the miss, one of these "unplug wire tests" should make a major difference, unless you have drivetrain issues in multiple cylinders. In that case, a good vacuum test and a compression test should show it. If it doesn't, I would check electrical again.) Remember, the miss should be easier to detect at idle... the engine is making less noise, so you can hear it better. So after removing a wire and then starting the engine, let it run for a little while. Mainly to let the idle come back down.
1SASjeepster is offline
post #23 of 25 Old 11-04-2011, 02:12 PM Thread Starter
Snicklfritz
well i understand your point. but i found the problem, o2 sensor was what thy call lazy. so it would not react as fast as it was supposed to. it has never idled this good thank you to all responded
p.s. stock manifold no riser
post #24 of 25 Old 11-04-2011, 06:31 PM
Duvalbulldog
Thats cool I have an issue which I thought there was a as well but it's my bottom gasket on my weber. If you get a chance invest in one of these best power improvement especially with 3.07 gears can't wait to see what it's like with 4.10 gears.
post #25 of 25 Old 11-04-2011, 08:09 PM
1SASjeepster
I am glad you found your problem.
Take care,
jeep wrangler yj misfires..i need help arif13yj YJ Wrangler Technical Forum 12 11-09-2011 12:08 PM
JK Wrangler newbie help :P LordArs JK Wrangler Technical Forum 17 03-21-2011 02:26 PM
HELP!! 97 Wrangler misfires, check engine light on now, running fine though..... usracer900 TJ Wrangler Technical Forum 3 11-24-2003 05:46 PM
?'s from a Wrangler Newbie with an '89 NJjeepster YJ Wrangler Technical Forum 5 10-22-2002 05:47 AM
