Newbie needs help - JeepForum.com
post #1 of 4 Old 08-08-2011, 05:07 AM Thread Starter
Lupey
Newbie needs help
Morning all. I have a 95 YJ 2.5 4 that I'm having a brake light problem with. Ok to start with ALL lights work on the front. Headlights, flashers, directions etc etc. On the rear I only have tail lights. No hazards, no turn or brake lights. When I turn on my directionals the green arrow stays solid on both left and right. I checked the brake light switch. I looked for a diagram but couldnt find one. My BLS has 4 wires on it. I do have power on one coming into it and power coming out. When I press the button the power is broken so I would think that the switch is fine. My question on that is out of the 4 wires are only 2 suppose to have power? Also I pulled the bulb and have no power going to the brake lights. Could it be a ground?
Thanks in advance all!
Correction. I have no directionals at all! Hazards work in the front but not in the rear.
Lupey is offline
post #2 of 4 Old 08-08-2011, 05:55 AM Thread Starter
Lupey
I got it. Guess that is what happens when you try to work on your Jeep at 530 in the morning. It was where the trailer harness was wired in. Removed that and connected the original wires and they all work now!
Lupey is offline
post #3 of 4 Old 08-08-2011, 08:36 PM
raynmaker
glad you fixed it. welcome to the club
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #4 of 4 Old 08-08-2011, 08:39 PM
TheNewbie
I was going to suggest checking the grounds on the housings. But it looks like you got it figured out.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
Newbie Jeep owner w/ a newbie Jeep question bigjim72 YJ Wrangler Technical Forum 12 08-21-2009 08:46 AM
help plz newbie coffey TJ Wrangler Technical Forum 22 10-19-2008 06:41 PM
Newbie, Thanks for the help! Loopmd YJ Wrangler Technical Forum 3 11-10-2004 08:52 PM
Newbie need help!!! F150ldc YJ Wrangler Technical Forum 8 11-02-2004 07:37 PM
A Newbie introduces himself and asks Newbie questions--film at 11. Copywriter TJ Wrangler Technical Forum 8 09-24-2004 11:20 AM
