Newbie need some help - JeepForum.com
post #1 of 3 Old 06-13-2013, 01:34 PM Thread Starter
FiremanDrew
I just purchased a 1993 YJ 2.5L manual for $1400. The motor ran fine until it was under a load causing it to sputter and loss of power. Check engine light diagnosis stated a code 27 fuel injector problem. Long story short checked compression number one at 30 so pulled the motor. I'm currently having it machined but I ran the block numbers and its a 95 2.5L. I know they are all basically the same but I was going to replace the clutch while its out. Should I look for a 93 or 95 clutch and which flywheel should I be running. Any help would be appreciated.
FiremanDrew is offline
post #2 of 3 Old 06-13-2013, 01:43 PM
rykemc
Flywheels are the same from 91-02. I would go with the 93 clutch. Not sure if they are different or not but that is what I would tell the parts guy.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #3 of 3 Old 06-13-2013, 02:08 PM Thread Starter
FiremanDrew
Thanks, that's what I was planning on going with the 93 clutch but didn't want to put in the wrong one only to take it all back apart again. There is plenty of other jobs I can't wait to do.
